FS Double Din Head Unit
I am selling my car stereo/DVD Player. It is only about 3 weeks old and in perfect condition. This unit has control for numerous devices. You can plug the expansion module into the back and the module will allow for 4 more devices plus one auxillary input. I also have the video iPod connection cable so that you can watch videos from your iPod and control the iPod from the head unit. The Expansion Module cost $100 and the iPod cable cost me $60. Purchased all items brand new. Still have all manuals that came with the radio.
This unit has the following inputs:
2 (two) Auxillary Inputs on back of radio and 1 Aux input on the Expansion Module
1 (one) iPod -- Took a photo of my iPhone 3G connected to show that the iPhone IS compatible with this unit!
1 (one) XM OR Sirius Satellite Radio
1 (one) Bluetooth Unit
1 (one) CD or DVD Changer
There is absolutely NOTHING wrong with this Stereo, my wife got a new car and it already has DVD Player built in.
Pics below show a little bit of dust, but trust me, there are no scratches or dead spots in the LCD touchscreen.
I purchased this Head Unit for $550, the Expansion Module for $100 and the video iPod cable for $60. I am asking $450 OBO for all of it. No trades. Cash or PayPal only. You can email at robert.almand@gmail.com.
Information below is taken from the crutchfield.com website!
General Features
Motorized Video Display: The Panasonic CQ-VW100U is equipped with a motorized 7.0" widescreen LCD monitor with touch screen controls. You can manually adjust the angle of the display using the touch screen controls or the tilt button on the unit. There are 6 angle settings to choose from.
Display Adjustment: You can adjust the display's contrast, brightness, color, and tint. The display's dimmer function can be set to one of three brightness levels.
Aspect Ratio: You can choose from the following screen modes:
Normal: displays 16:9 widescreen format pictures that fill the entire screen width, and 4:3 (conventional TV) pictures display with black bars on either side
Full: expands 4:3 pictures horizontally to fill the entire width of the screen, distorting the picture slightly but retaining full image height
Zoom: expands 4:3 pictures both horizontally and vertically, filling the screen without distorting the picture but cutting off the top and bottom edges
Just: expands 4:3 pictures horizontally only at the edges
ID Code: Prior to operating this unit, you can assign a 4-digit ID code for security. Once the ID code has been set, the unit cannot be operated without entering the ID code if the main power supply is disconnected and then reconnected.
SQ3: The 3-band parametric EQ lets you adjust the level of three frequency bands: Bass, Mid, and Treble. You can select the center frequency for each band as follows: Bass (60Hz, 80Hz, 100Hz, 200Hz), Mid (500Hz, 1kHz, 2kHz, 3kHz), and Treble (10kHz, 12kHz, 15kHz, 18kHz). The level of each frequency can be adjusted from +12dB to -12dB in 2dB increments. You can also choose from the following SQ presets: Rock, Pop, Vocal, Jazz, Club, and Flat. In addition, the unit offers separate bass and treble adjustments of +/-12dB.
Dolby Digital/DTS Decoders: The CQ-VW100U has built-in decoders that allow you to enjoy Dolby Digital and DTS as a 2-channel down-mix.
MP3/DivX Compatible: This unit can play MP3 and DivX files recorded onto CD-R, CD-RW, DVD-R, or DVD-RW discs in ISO 9660 Level 1/Level 2, Apple Extension to ISO 9660, Joliet, and Romeo. The player can support up to 999 files, 999 files in one folder, 8 levels, and 255 folders.
Subwoofer Preamp Output: The volume level of the subwoofer preamp output is adjustable from -12dB to +12dB in 2dB increments. The subwoofer preout is a single, unfiltered, full-range output. If desired, you can turn off the subwoofer output in the menu.
Rear View Camera: You can connect an optional rear view camera to the unit through a dedicated rear camera input. The camera must have an RCA composite video connector. When the violet/white wire in the wiring harness is connected to the vehicle's backup light circuit, the CQ-VW100U will automatically switch to the rear camera input whenever the vehicle is placed in reverse gear.
DVD/Video CD Features
Fast Forward/Reverse: When playing a DVD or Video CD, the speed of fast forward and fast reverse change incrementally in 4 steps (2x, 4x, 8x, and 16x) as the corresponding button is held down.
Slow Motion: When playing a DVD or Video CD, you may move forward through the program being played in slow motion at about 1/3 normal speed. Slow motion playback cannot be performed in reverse.
Repeat Play: When playing a DVD, you can repeat the current chapter. When playing a Video CD, you can repeat the current track. For MP3 and DivX discs, you can repeat the current track or folder.
Multi-Angle Display: This function allows you to choose the viewing angle of scenes that were shot from a number of different angles.
Note: This function is limited to DVDs recorded with multiple camera angles.
Dynamic Range Compression: This function reduces a Dolby Digital soundtrack's dynamic range so you can hear quieter dialog without being overwhelmed by loud sections. You can choose a setting of Minimum, Standard, or Off.
External Device Controls
System-Up Connector: The CQ-VW100U has a rear panel-mounted System-Up connector which allows you to add a single external device, or with the optional Expansion Module (133CYEM100), add up to 4 components. Most of the optional components will require an adapter cable in order to make the connections. The components that can be connected to the head unit via the System-Up Connector include:
iPod: You can connect an iPod using the CA-DC300U Direct Cable for iPod (133DC300) or CA-VDC300U Direct Cable for iPod with Video. Compatible iPods using this connection method include the following iPods and software available through September 2007:
4th Generation iPod/ver.3.1.1
5th Generation iPod/ver.1.2.1
iPod photo/ver.1.2.1
iPod mini/ver.1.4.1
1st Generation iPod nano/ver.1.3.1
2nd Generation iPod nano/ver.1.1.3
Note: Functionality except for video playback (not supported) via the System-Up Connector has been confirmed by Crutchfield for iPod classic, 3rd Generation iPod nano, and iPod touch. These iPod models require an authentication chip in order to output video.
CD/DVD Changer: Using the optional CA-CC30U Conversion Cable (133CACC30), you can connect the optional Panasonic CX-DP880U CD changer, or the CX-DH801U DVD changer.
Satellite Radio:
XM Satellite Radio: You can connect the optional XMDirect² package (700XMPAN1), which consists of the CNP2000UC tuner and CNPPAN1 adapter cable, for XM Satellite Radio programming. A subscription to XM Satellite Radio, plus downloading of firmware to the XM Tuner is required in order to receive XM programming.
Sirius Satellite Radio: At this time, the CA-LSR01U Interface Adapter, which allows you to connect the optional SiriusConnect SC-C1 receiver to this head unit, is not yet available. Until the interface adapter is available, you can connect a Sirius plug 'n play unit (such as Sportster, Starmate, or Stiletto) to one of the unit's auxiliary input.
Bluetooth: Using the optional Panasonic Bluetooth unit CY-BT200U (item # 133BT200), you can make and receive phone calls hands free on a compatible Bluetooth-enabled cell phone. You can also control and listen to Bluetooth audio devices. (This head unit does not support the CY-BT100U Bluetooth unit.)
Optional Expansion Module (hub unit): Connection of the CY-EM100U Expansion Module (item #133CYEM100) allows you to connect up to 4 of the above-listed optional components. In addition, the Expansion Module has an audio/video auxiliary input to allow you to connect a portable audio or audio/video device. The head unit has a dedicated composite video input (labeled Ext Video In) for use with the Expansion Module.
Inputs and Outputs
Audio/Video Inputs: The CQ-VW100U has two rear panel A/V inputs. They feature composite RCA and stereo audio jacks, allowing you to plug in an A/V source such as a camcorder, VCR, or game console.
External Monitor Output: This unit provides a single female RCA composite video output (labeled "Video Out"), which allows you to send a video signal to an external overhead or headrest monitor.
General Features
iPod mini/ver.1.4.1
Satellite Radio:
Inputs and Outputs
Reverse cell phone lookup
Yap, this is a good thing. Looking something like this but for free. Very rare cases when you need to get a lookup and I dont think that its reasonable to pay for it to use 1 or 2 times in whole life-time))))
