How hard is it to install an alarm?
Well I was whoring ebay and I found there is a lot of alarms that go dirt cheap. I was thinking maybe I could buy the and if only I knew how to install them I could really make osme good money off of this. People would pay some decent money for one of these to be put in. So exactly how hard would it b to try to install one?
Doesn't www.installdr.com have alarm wiring diagrams? Without a wiring diagram for the specific vehicle...you're basically screwed. It's not the easiest thing in the world.....
Originally posted by Afboy143
nothing is really the easiest thing in the world. You just gotta b able to learn how to do it
Guest
Posts: n/a
I can get yuo the wiring diagram for any make/model.. and where each wire is located... but I am not liable for when you fry your car's electrical system. Let me know the info on your car.
1999 ford explorer sport SOHC
power everything, power windows power door locks power all kinds of shit
I have a few more questions
how hard would it b to install one of those keyless entries on a car that isnt automatic door locks
Guest
Posts: n/a
Code:
| ITEM | WIRE COLOR |POL| WIRE LOCATION | | 12V|yellow |+ |ignition harness | | STARTER|red/lt. blue |+ |ignition harness | | IGNITION|green/purple *1 |+ |ignition harness | | ACCESSORY|gray/yellow *1 |+ |ignition harness | | SECOND ACCESSORY|black/green |+ |ignition harness | | POWER LOCK|pink/yellow |- |driver's kick panel | | POWER UNLOCK|pink/green |- |driver's kick panel | | LOCK MOTOR|pink/black | |driver's kick panel | | UNLOCK MOTOR|red/orange | |driver's kick panel | | DISARM DEFEAT|pink/orange *2 | |driver's kick panel | | PARKING LIGHTS +|purple/white *3 | |driver's kick panel | | PARKING LIGHTS -|white/purple | |driver's kick panel | | HEADLIGHTS|red/yellow |+ |light switch | | DOOR TRIGGER|black/lt. blue *4 |+ |driver's kick panel | | DOME SUPERVISION|black/lt.blue |+ |driver's kick panel | | TRUNK/HATCH PIN|common with doors | | | | HOOD PIN|tan/lt.green |- |driver's kick panel | | FCTRY ALARM ARM|arms on lock *5 | | | |FCTRY ALRM DISARM|dk. green/purple |- |driver's kick panel | | TACHOMETER|tan/yellow | |PCM *6 | | SPEED SENSE|gray/black |8 |PCM *6 | | BRAKE WIRE|lt.green |+ |driver's kick, brake switch | | HORN TRIGGER|yellow/lt. green |- |steering column | | WIPERS|wht & dk.blu/org *7 |+ |wiper motor or relay | | LF WINDOW UP/DN|wht/blk - red |A |at motor in dr door | | RF WINDOW UP/DN|wht/yel - tan/lt.blu|A |sw dr door or dr kick | | LR WINDOW UP/DN|gry/org - yel/lt.blu|A |sw dr door or dr kick | | RR WINDOW UP/DN|yel/blk - red/blk |A |sw dr door or dr kick | | POWER ANTENNA|lt green/purple |+ |radio |
NOTE: Some models of this vehicle are equipped with PATS (Passive Anti Theft System). Use DEI module 555F to over-ride during remote start. *1 Two wires each at switch, both are common, only need to power 1 each during remote start. *2 You may also use the pink/green power unlock wire. *3 Also found to be white/black at the rear of the switch. *4 To avoid the dome light delay and dome light time-out use the separate door triggers. In the drivers kick panel find yellow/black for the drivers door, lt. green/yellow for the drivers rear door, and white/purple for the rear hatch. In the passengers kick panel find gray/red for the passenger front door, and pink/lt. blue for the passengers rear door. All five wires are negative trigger and must be diode isolated together. *5 Arms on lock only with door open. It is necessary to send a signal to door trigger as well as lock to arm factory alarm. *6 The PCM is located at the top of the firewall towards the passenger side, the tan/yellow tach wire is also found at the back of the instrument cluster. *7 Also found yellow/white (-) at the firewall connector.
