help wiring my sub, and visors
Old 07-14-2004 | 06:49 PM
Bumpin Expo's Avatar
Reppin' the 813
how many ohms is that
Old 07-15-2004 | 01:12 AM
eli's Avatar
eli
around 3 i think
Old 07-15-2004 | 01:13 AM
eli's Avatar
eli
the way its working is im hookin 2 terminals to 1 channel on the amp. and the other 2 on the other channel. its weird but its working.
Old 07-15-2004 | 09:45 AM
Derek's Avatar
Whitey on the Moon
if you have it wired parallel/series it should be 1.5
Old 07-15-2004 | 02:34 PM
Reppin' the 813
did u ASk for the quad 1.5 ohm coils or what? did you order the sub directly from SI?
Old 07-16-2004 | 01:11 AM
eli's Avatar
eli
no i got it from a guy off this site. it is wired as series parrallel or supposed to at least. is that series parallel? i also noticed just now, im going to need 2 terminals which sucks since i just fabricated my box yesterday. woops but no biggy. finally done building and install should be this weekend finally can enjoy what my summer has been about.
Old 07-16-2004 | 06:27 AM
  #17 (permalink)
TIM TIM TIM's Avatar
could be worse
i hate odd speakers/wireing.. to confusing for me
aim:because tim said
Old 07-16-2004 | 01:46 PM
  #18 (permalink)
Derek's Avatar
Whitey on the Moon
no need for another terminal....
this would be a 1.5 ohm load dont know if your amp can go this low with out overheating or going into protect
Old 07-17-2004 | 03:45 AM
  #19 (permalink)
eli's Avatar
eli
yeh my amp has a protection mode on it that says i can use it lower than 2 ohms so its ok though i already made the other hole in the box anyway for the terminal.
