Box builders, take a look.
Old 05-09-2005 | 01:45 PM
foesicks's Avatar
Default Box builders, take a look.
I need to make a box that is .5 sealed for a 10" sub. If im using 3/4 mdf what would the dimensions of that box have to be. I know you have to factor in the basket size and what not but it dosnet have to be perfect. If it helps the sub has a 100oz magnet. TIA
SOHC 1.6 VTEC
----CRX DX-----
Old 05-09-2005 | 01:56 PM
Miles's Avatar
It's a wooden pickle.
well, unless your sub was made by a company in syria, they've probably got a website with tech specs on your sub, including the sub's displacement.
and there's a damn near infinite number of ways you can build a half cube box, just sit down with a pencil and paper (and calculator if you don't know your times tables) and work out height x width x depth. it's not hard, i promise.
Old 05-09-2005 | 06:23 PM
foesicks's Avatar
I thought thats what your on this site for miles? Im only in second grade, i havent learned times tables yet. Can you help me out?
SOHC 1.6 VTEC
----CRX DX-----
Old 05-09-2005 | 06:31 PM
Miles's Avatar
well, unfortunately it's impossible for me to throw anything out but completely arbitrary numbers because you haven't posted up how much actual space you've got to work with in your trunk, if there's any design limitations (i.e. can't be taller than 12 inches, has to fit in your spare tire well, or something similar) what the mounting depth of your sub is, etc. etc. there's entirely too many variables chief.
Old 05-09-2005 | 07:08 PM
foesicks's Avatar
Ahhh.... This crummy box building program i just downloaded should help me out.
SOHC 1.6 VTEC
----CRX DX-----
Old 05-09-2005 | 07:48 PM
TBSpyder's Avatar
height x width x length = ? / 1728 = cubic square ft.
And what 10" sub with a 100oz. magnet only requires .5 cubic ft.???
Old 05-10-2005 | 04:21 AM
foesicks's Avatar
I like it tight Thats what the .5 is for.
SOHC 1.6 VTEC
----CRX DX-----
Old 05-10-2005 | 05:54 AM
adero's Avatar
Uber 1337
just make it 12" by 12" by 8" and you'll be good. it's about 0.53 ft^3 internal volume, so after displacement, it shouold be a little under half a cube. just throw some polyfill in before the sub goes in there, and it'll help.
Old 05-10-2005 | 06:48 AM
TIM TIM TIM's Avatar
could be worse
.5 is to small. Mine says to use .5-.8 and there close to .5.... I had to throw in a ton of polly fill to get a decent sound out of them
aim:because tim said
Old 05-10-2005 | 08:07 AM
foesicks's Avatar
The specs say. 5 seal or .8 ported. I guess I could make the box 12"x12"x10" and then add pollyfill until I like how it sounds. Thanks for the advice.
SOHC 1.6 VTEC
----CRX DX-----
Quick Reply: Box builders, take a look.
