alternator power wire question
Old 05-23-2005 | 07:02 PM
integralsgreen's Avatar
Default alternator power wire question
im upgrading the wire from the alternator to the battery. on my car the stock wire goes from the alt. to a fusebox then from the fusebox to the battery. should i jus run the new wire strate to the battery n keep tho old power wire from the fusebox to the battery as a batter to the fusebox? if you have any clue what im talkin about lmk lol. also what gague should i upgrade to? i still have the stock alt. but am upgrading as soon as i have the cash
Old 05-23-2005 | 07:33 PM
DANGERANGER's Avatar
Shop Bitch
Yes you can but you need an inline fuse within 12" of batt. depending on current draw 8ga usually does the trick. I had 4ga and a 250amp GM alternator conversion on my EF.
Frank
Enhanced Concepts
727-638-4667
Old 05-23-2005 | 07:38 PM
TBSpyder's Avatar
Go with 4 guage, upgrade your batterey's grounds as well. Most stock vehicles run a wire from the alternator directly to the battery, without a fuse...which is also how we do it when upgrading wiring, never had a problem.
Old 05-23-2005 | 07:41 PM
well the upgrade alt im getin is a 175 amp. dose it hurt to go with to thick a wire if im still runnin a stock alternator?
Old 05-23-2005 | 08:52 PM
93ex's Avatar
Just Ledoux it!
my blazer had a wire sans fuse from the alt to battery stock, if I remember correctly.
of course now its 0/1 but hey.
And oin stock (well reman but stock amperage) alt.
Old 05-24-2005 | 05:34 AM
TBSpyder's Avatar
No.
Old 05-24-2005 | 03:14 PM
thanks guys. wired it up n works great.
