in dash dvd ebrake bypass
Old 06-06-2005 | 02:38 AM
Bumpin Expo's Avatar
Reppin' the 813
this guy gets owned all over ahq
Old 06-06-2005 | 06:19 AM
kpr10is's Avatar
Maximaniac
you would think he would have learned something from his f/s thread
Old 06-06-2005 | 08:55 AM
SpyderHatch's Avatar
If you just dont hook up the VSS and add a switch it wont matter trust me weve done a few this way, well theyve came back this way. You guys are ass clowns seriously.
Old 06-06-2005 | 11:09 AM
Chris's Avatar
Sugar Daddy - Miami Bound
Alpine = PAC TR7 Module
$25 + hookup 3 wires = success
Humanitarian, Philanthropist, Champion of the arts, supporter of single moms, and role model for misguided youths
Old 06-06-2005 | 04:32 PM
kender's Avatar
gadget man
I like the alpine unit, and eclipse is also a good unit but I have heard more about alpine than eclipse ( I am guessing it is cause the eclipse stuff is more $$$) I will look at the wiring diagram when I get it, but it sounds like it is a basic unit as far as fooling the signals, ebrake, and or foot brake, to a switch that I control instead of the ebrake switch doing it. as far as gps..... on long trips maybe but the last time I went on a long trip I mapped it on yahoo first and it was 2 years ago, so if I need gps for some reason then I can worry about that.
instead of opening the brain and soldering it, could you use an adapter for the gps antenna, or is the antenna hard wired and not on a plug?
does this even apply to the alpine 300 or 310?
it sounds like the box on ebay is nothing but a relay setup, whether it uses transistors to do it I don't know, but it would be easy enough to duplicate.
thanks for the help guys.
U.S.S.A Crew Member #001
Old 06-07-2005 | 05:39 AM
Chris's Avatar
Again - if you go with the Alpine, but the PAC module I listed above. It's foolproof, it's cheap, and there are no switches to deal with. Forget about all the other stuff.
Old 06-07-2005 | 06:31 AM
  #17 (permalink)
93ex's Avatar
Just Ledoux it!
+1
K.I.S.S.
Old 06-07-2005 | 06:41 AM
  #18 (permalink)
Chris's Avatar
Originally Posted by 93ex
+1
K.I.S.S.
Don't get fresh with me asshole!
Old 06-07-2005 | 06:05 PM
  #19 (permalink)
kender's Avatar
gadget man
I may spring for it just to save myself time in not having to design a circuit myself, but I will definately hook it up to an on off switch just so I can make it look like it working the way it is supposed to. I am not sure if florida has laws against the driver being able to view the dvd's while the vehicle is in motion, if not the screw the switch, if so then I'll put it in.
Old 06-07-2005 | 06:14 PM
  #20 (permalink)
kpr10is's Avatar
Maximaniac
illegal in all 50 states
