who can build or tell me where to go for a custom box?
Originally Posted by integralsgreen
i use wood glue to hold it together then silicon all the seams inside the box when im done
Originally Posted by NoTLaDStyle
hey that works too, I just like the idea that my silicon is squishing together between those boards eliminating every milimeter of possible escape for the puny air molecules. leaving them helpless to resist the bone crushing high PSI factor that will slowly drive them into atoms as the bass pumps....
Home Depot sucks ass at cutting wood, and so does Lowes. At least every location its ever been to.
+1 to adero and john. Either DIY or get it done professionally.
Originally Posted by kpr10is
Wood glue is what actually holds your box together. Screws just let the wood glue dry. Please take a video of a sub blowing your box to pieces once it happens with only silicon
pm me, Buy the wood and give me 15 bucks and ill do it. I usually use staples from an air staple gun with wood glue then calk (sylicone based) for all of the seems. havent had one come apart yet.
Silicone is much stronger than wood glue once it dries. Even without the screws for support, I can jump on a siliconed box. Please take a video of you jumping on a box made with wood glue and no screws without breaking
dont know what kinda wood glue your usin but usually the wood itself will break befor the seal between the 2 glued peices will.
Exactly. I've yet to see silicone caulk outperform wood glue.
