Flip up dvd in replace of airbag
Old 10-29-2005 | 09:40 PM
95InTeGrAgRl's Avatar
?DiD u JuSt GeT sMoKeD?
well thats simple enough put plastic over everything
MeSs WiTh ThE bEsT dIe LiKe ThE rEsT!
Old 10-30-2005 | 06:04 PM
integralsgreen's Avatar
dont blow it! if your if its a teg it coms out verry easy. take out the glove box and remove the 6 10mm nuts and lift it out. i actually thought about doin this in my teg. the plastic peice can be seperated from the bag so you can use that to look like the airbag is still there untill you hit a switch and flip it up. alls you would need is a hindge, window moter and some creativity. btw i have disasembeld the airbag in my car so i know it can be taken apart without blowing it. dont risk having to replace your windshild. it comes out all to easy!!! send me a pm if you need more info or help cuz i was gonna do this on my teg. just dont got the mony
Old 10-30-2005 | 06:08 PM
btw i got a extra set of airbags. fl dosent have vehical inspections so i wouldent worry about breaking laws just dont kill anybody cuz theres no airbag. but in case you move to a state where your car needs to have a safty inspection it would be wise to have a spair airbag to toss in to pass inspection
Old 10-30-2005 | 06:19 PM
theres one way you could do it. i would make it flip up tho instead on just making it rise vertically. but i gess if you wanted to keep it simple that works. not to clean lookin tho in my opinion. looks flimsy
Old 11-01-2005 | 03:58 PM
TBSpyder's Avatar
Originally Posted by URBANRCR
you gota blow the airbag out there's a way but i cant exactly remember it.
Are you retarded? You don't "blow it out."
1st, yes, placing something in the air bag space has been done many times before.
2nd, the air bag and all it's components are removable. In addition, these components are usually very valuable. You can usually turn around and sell it for as much as a couple thousand dollars.
3rd, don't attempt this yourself, leave it to a professional, specifically a professional who's done it many times before.
When it all boils down, I'm willing to bet your best option is to just find another place to put your dvd player because not only are you going to fuck your car up, it's also going to cost a pretty penny.
Old 11-01-2005 | 05:32 PM
Notladstyle's Avatar
King of Ricers
yeh airbag work should be left to teh professionals... that means no1 from this forum
notladstyle.blogspot.com
Old 11-04-2005 | 03:50 PM
  #17 (permalink)
im certified to work on airbags. well i will be once i pay the 5 bucks for my icar points
Old 11-07-2005 | 07:05 AM
  #18 (permalink)
paintballa213's Avatar
Adam
i have done this to my car. very easy! i had to pull the pass side airbag for my ps in the dash and i took out the airbag on the driver side for my racing steering wheel. everything is removable. just take ur time and make sure to disconnect your battery and you are fine.
Adam
05 BMW 745LI
05 BMW 325I
94 Mustang V6 (ls1 Powered)
93 Mustang Notch (ls1 turbo project)
