getting a deck installed
Old 11-02-2005 | 09:35 AM
psychx's Avatar
theres a plastic clip with the power wires and a bunch of cut wires coming out of it
the clip can attatch to the head unit
theres also a bunch of other wires
Old 11-02-2005 | 09:53 AM
psychx's Avatar
Old 11-02-2005 | 11:30 AM
kpr10is's Avatar
Maximaniac
The shape of your factory harness
If installed correctly, there should be a harness like below that the pioneer deck wires connect to, that plugs directly into your factory one.
Old 11-02-2005 | 12:15 PM
psychx's Avatar
i think im missing my factory harness??
Old 11-02-2005 | 12:35 PM
GradeA_TireFryer's Avatar
All American, rice eater!
still do it for $20
Old 11-02-2005 | 03:18 PM
psychx's Avatar
ok i got it setup, it powers up, everything is working, except this:
i only hooked up the 2 back speakers, but only one of them is working, they appear to be hooked up correctly and i was told it works, any ideas? the other works great
Old 11-02-2005 | 03:31 PM
  #17 (permalink)
Notladstyle's Avatar
King of Ricers
stop money mongering tirefly
psychx - run new speaker wires.
notladstyle.blogspot.com
Old 11-02-2005 | 03:43 PM
  #18 (permalink)
psychx's Avatar
you think it could be the speaker wire? cause im pretty sure it should be working... i believe that is the speaker that has a bunch of wire problems tho, i want to get someone to look at it tho, it seems like something might be messed up in the connections to the speaker, the positive and negative connectors but im not sure
i really wanted to get this done tonight lol, ive gone so long without audio (like 2 months)
Old 11-03-2005 | 06:41 AM
  #19 (permalink)
King of Ricers
pull the speaker that is working and plug it into the plug from the one that isnt. Any sound? if not then run new wires and save yourself the headaches. If you get sound then you know its a bad speaker. Go to walmart and drop $30 on a pair of el cheapos and they will still sound better than stock, or alternatively, walmart also has OEM speaker replacements for 10$
Old 11-04-2005 | 04:36 PM
  #20 (permalink)
SSpiro's Avatar
Errare Humanum Est
Originally Posted by GradeA_TireFryer
still do it for $20
I got 18.90 on it.
