I have 3 audiobahn alum12q's
These subs are dual voice. Subs are dual 6 ohms. I was wondering if anyone can help me pick out an amp to run on these
you use dual 6 ohm subs when you run them in 3's. the jl 12w6's are dual 6 ohm and the audiobahn alum12q's are dual 6 ohm. when you run 3 subs you have to go with dual 6 ohm and there arent too many options in dual 6 ohm. you can go with the jl's for about 450 a sub or the audiobahns for about 150 a sub.
this is the wiring diagram for 3 dual 6 ohm subs
I need a 1 ohm stable amp that is putting out around 3000 watts.
