Kicker L7s?
stop while you're only a few miles behind =/
I guess personal preferance. But you can get 2-3 W6v2s for the price of one W7 and they sound better plus bang pretty hard too.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
The w6's go head to head with the w7 spl-wise. But the w7 has it's nuts in the sq department. I'd personally take a couple w6's over a w7, mainly because they require less power to get them moving.
I ran both the 13W7's and the 13w6v2's and i would definetly say the w6v2 is the better of the two. The sq is definetly better on the w6v2 the spl is about a tie. But either way the both kill the L7. Hands down.
JL Audio all the way!!!
^^R.I.P. 08/04/04-11/28/05^^
I hate illegals in 97 Chevy Blazers!!!
L7's are good speakers, i have 4 of them and 1 solo-x and they slam, but like stated in earlier post, sq is not nearly as good a a w7 would be, solo's put out a RAW thump, i personally would go with the w7 if you have the money and you don't need a $1000 amp to push it, you can find QUALITY amps that push out the power necessary to power your subs
and you don't need to get a more powerfull alt. i've had 2 solo 12's and 1 solo-x in my civic with just a second battery and my lights don't even dim. if you have the money tho, and want the xtra power, i would definatly buy one.
PLAY PAINTBALL LOCALLY
http://www.blitzkriegpaintballfield.com
^^^^^^Click There^^^^^^
Modified Racing Inc. (Blown99civicSi) John Solaro
https://www.tamparacing.com/forums/h...t=john+scammer
https://www.tamparacing.com/forums/h...acing-inc.html
And how many watts were you running (true rms)? 1000 rms and over is really pushing it. I've seen cars turn off because their weenie alternator couldn't keep up. Your car is drawing the brunt of the power from the alternator when it is running. I know most Hondas have miniscule alternators and even smaller batteries (it's like a tractor battery).
^^What he said, I'm running close to 2500k right now and my car can barley handle it, and I have a 140amp alt, with big 3 and 0 gauge to the trunk. (Can't wait for that 200amp alt)
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
i got a kx1200.1 watt running 2 of my solo-barics OR 1 solo-x. and a kx800.4 running my highs, and i have never had a problem with my system. i've been running this setup for about 4 years or so now. since the square solo's came out. if i had the money i would definaly buy a new altenator but i'm broke so what i have have been doing fine.
hey rconcheiro, if you want, i will meet up with you so you can here my system to help you better your choice on which subs you want to buy
