Anyone familiar with Nissan / Infiniti Stereos or Stereos In General ?
Old 11-15-2006 | 12:03 PM
Notladstyle's Avatar
King of Ricers
its called bass attenuation , a similar function to "LOUD" on aftermarket stereos, the high notes and low bass notes are increased at low volumes, and increased at higher volumes.
Its hardcoded into the bose headunit so theres really nothing you can do about it. The bose system is designed for clean sound throughout the volume spectrum and the bose sub will clip at higher volumes unless it is attentuated.
You could replace the headunit but the sub will probably clip once you reach the volume it currently slopes off at.
As for replacing the sub, the bose sub has a very high sensitivity and is usually an uncommon ohm load. if you use a load lower than it then it will burn the amp out. if its higher you will lose a lot of power and it will sound very poor.
notladstyle.blogspot.com
Old 11-15-2006 | 04:20 PM
TIM TIM TIM's Avatar
could be worse
so basically replace all or nothing
aim:because tim said
Old 11-16-2006 | 08:11 AM
GradeA_TireFryer's Avatar
All American, rice eater!
no... pull out the sub in rear tray, allowing a "port" from the trunk - install subs& amp in trunk.
Pirate Customs
Sound, Security & Style..... anything for your ride
Old 11-16-2006 | 08:23 AM
King of Ricers
this will not eliminate the headunit's bass attenuation but with more power comes more thump.
Old 11-16-2006 | 09:23 AM
the727kid's Avatar
It won't, but removing the rear sub and adding a nice sub/amo combo wil make it sound MUCH better.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old 11-16-2006 | 03:08 PM
King of Ricers
ive heard the infinity bose combo and it takes more than just an average set of subs to beat that sq
Old 11-18-2006 | 05:50 AM
King of Ricers
the speakers are easy to change. tapping the preamp is also easy to do.
its the bass thats an issue.
Old 11-18-2006 | 06:15 AM
P057's Avatar
isuck
Originally Posted by Scott
I have come to find out it is royal PITA to change anything in this system. Every speaker has a pre-amp, every speaker runs on some odd ohm range, and the head unit is not something I am going to touch considering most of the settings for the rest of my car are controlled through the head unit.
unfortunately most new cars are like that, especially with the stock "higher quality audio system installs" its rediculous.
When i buy a new car it'd be nice to opt for no stereo or anything installed.
if i ever buy a new car.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
