Dummy Plate
tint
I think it'd be a pain to find/get for a car that it doesnt come with some sort of stock offering, otherwise i'd say junkyard/one of the for sale forums in the proper tech forum/dealership.
depends on the unit but usually you either have to buy a pulse interrupter or use a toggle on the e-brake wire.It tricks the unit making it think that the e-brake is on.Hope this helps.Oh and if you use a toggle the other wire must go to ground.
Captain Morgan: When you die and go to heaven,you'll talk to God. THIS will be the stuff you'll smell on his breath.
what model headunit?
he means take apart the stock headunit and glue all the button faces into place and put it over the aftermarket unit
its this one
eBay: NEW DUAL XDVD8181 7" INDASH TV DVD MP3 RECEIVER (item 180080998071 end time Feb-07-07 08:52:21 PST)
tell him the only bypass he needs is to bypass using that deck
Just kidding, try grounding the ebrake wire(as in connect it to the negative power wire) if that doesnt work, try tapping it to the ground while the unit is on and see if it works. if it does then u will need a togglt switch to turn on and off.
