Parking brake wire issue. Panasonic in-dash cq-vd7001u
Just kidding... Are you talking about the headunit harness or the vehicle harness?
Haha! Rep'd. We're talking about the Head Unit Harness. I think I have the radio harness rather then the in-dash one.( Thanks to Stereorama ) I went to AVE and they told me that I could just try sticking a wire in every single extra pinout until it seemed to work. Any ideas?
Take a picture of your harness from the wire side so we can see what you are working with.
My sister took my camera to LA Here's where I'm at. I have the to far left pins top and bottom empty. the two tires that are closest to them are the postive rf+ and the top wire is RR positve. There's a pin open between 12 volt ignition/switched and left rear negative. The last open pin is on the bottom 2nd to the right in between 12 volt battery/constant and power antenna.
so 4 pins total that are empty? I would say ground each one but you might fuck it up.
