AMP help
Old 12-03-2007 | 03:45 PM
bebeleruetatsu's Avatar
Registered Addict
Default AMP help
SO.. I have been looking online to try to figure this out but I have gotten no where. There are sometimes when the radio turns on the the amp will turn off abruptly causing a loud popping sound. It tends to happen more when it is warm outside, because early mornings and late nights it is very rare. A little info on the set up, it is a 4 channel amp hooked up to only the 6 speakers, no subs. In between the amp and the speakers there are audiobahn boxes that were described to me as micro-amplifiers basically... is that what they really are I doubt it. But the connections go from the amp to these two 5x5inch audio bahn boxes then to the speakers, which are audiobahns as well.
My question is.. why is the amp turning off and how do I stop it?
Yes it is grounded, no the ground and power aren't touching, I have them surrounded by electrical tape and I am planning to have the connection sodered but want to make sure I figure this out. It is really getting annoying. Please help!
Old 12-03-2007 | 04:06 PM
P057's Avatar
isuck
4 channel amp into 6 speakers?
Did you consider the fact that you may have wired it improperly?
How DID you wire it up? Pictures and very detailed explanations would help.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old 12-03-2007 | 04:10 PM
jriggs's Avatar
is better than you™
also sounds like you might have a problem with you remote on
Old 12-03-2007 | 04:19 PM
Registered Addict
Yeah i did consider that I wired it incorrectly.. LOL trust me I don't know too much.. I could describe the wiring better if I new what those other boxes were. i will try to take pics tomorrow in the light and I'll post them up.
As for the remote on, I actually thought that could be it so I took the entire wire out and re ran it... still happened.
Should I be using a different amp, I took it to circuit city and the guy who check it out said it was wired properly and that I needed to keep the 4 channel.
Old 12-03-2007 | 04:36 PM
Notladstyle's Avatar
King of Ricers
remove the boxes.
notladstyle.blogspot.com
Old 12-03-2007 | 04:41 PM
Registered Addict
do you know what I am describing because if you know what they are I'd love to figure it out.
yeah I bought the car with the set-up it has except i had to add the amp because the guy took out the amp and the cd changer.. i just recently replaced the head unit but even before that I had the same problem
Old 12-03-2007 | 05:06 PM
King of Ricers
If you have component speakers, they are the crossovers that filter the bass from the tweeters and the highs from the midrange.
Now that I think about it, the problem is with the turn on lead being powered before the headunit is. Where do you have the turn on lead connected?
Old 12-03-2007 | 05:24 PM
Registered Addict
But that doesn't explain why it only happens sometimes.. wouldn't it always happen if it was the turn on lead? I'm really close to just unhooking the crossover things and rewiring it all straight back into the head unit.
Old 12-03-2007 | 06:42 PM
jriggs's Avatar
is better than you™
is the 'crossover thing' a line out converter or an eq of sorts?
i had tons of probelms with my old legacy crossover/eq ditched it and used the amps eq and everything sounded a ton better. my problem with popin occured bc my amp did not have a soft on and it had a very soft on so the amp would kick on and then a second later the eq would kick on making a pop. soft on is a delay on which is supose to get ride of the pops
hope that makes sence...
-james
Old 12-03-2007 | 10:10 PM
King of Ricers
It does explain it.
it does it when the amp is powered up before the headunit is - possibly when you turn the radio on after the car is already running...
