Problem with system
if the lights dont dim, the charging system is fine - check your amplifiers ground points.
Yeah, it’s probably a ground problem. Make sure you’re grounded to unpainted metal and you have adequate gauge wire in use.
No offence I can understand not having great English grammar, when I try to talk or write in any other language it’s real bad. You can get an add-on for internet explorer, firefox, safari, or any web browser that will correct most your errors or just a translator add-on if you’re better in a different language. It’ll make it much easier to read and you’ll catch a lot less crap from everyone around here.
Where are you from man?
It only gets quiet when you brake, but is good at idle and when moving? Sounds like something might be loose.. check all your connections.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
