Custom Faceplate for double Din$$$?????
Old 11-09-2008 | 04:28 AM
burgy240's Avatar
Offset-----Less is MORE!!
Default Custom Faceplate for double Din$$$?????
ANyone know someone who does good work and can produce a double din faceplate for around a nav system in an I35? any estimates on how much it would be. here is a pic so you can see the shape of it. It is not a rectangular piece. I know they make a peice to replace the whole thing but I was wondering if anyone local could do this? Thanks
Looking to buy or sell Real Estate, give me a call.
http://liberty-vip.com Flush ≠ VIP. Spread the word in 2012
Old 11-09-2008 | 04:00 PM
Soundwaves's Avatar
Give me a call at the shop, we can fabricate that for you.
pete
Hours Monday By Appt.
Tues-Sat 10-6
Auto Sound, Security, Accessory, and Fabrication
10134 Fisher Ave #A3
Tampa, Fl 33619
813.684.6060
Old 11-09-2008 | 05:31 PM
MCOR's Avatar
There are no aftermarket kits available for the I35's at all (single nor double din) as you must have found out by now. It can be fabricated from the factory piece that you have there. If helps if you already have the double din replacement that you will be using. We can fabricate the surround for you same day on these. You can check out the shop under "TR Shop Forums" MCOR Automotive LLC.
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
Old 11-10-2008 | 09:21 AM
GradeA_TireFryer's Avatar
All American, rice eater!
$250 - look factory
Old 11-10-2008 | 11:46 AM
the727kid's Avatar
$250? Holy shit lol... all you got to do is dremel out a hole, glue the trim ring in place and duraglass over it, hit it with paint and your done.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old 11-10-2008 | 11:50 AM
cut it out and fit trim ring, fill sand prep for paint, texture, then get color code for factory paint, mix paint, dry, clear, install - i would say you you have 4-5 hours to make it right -
i normally get $85 hour.
Old 11-10-2008 | 12:33 PM
TBSpyder's Avatar
Overkill.
Old 11-10-2008 | 01:25 PM
luke81's Avatar
Originally Posted by TBSpyder
Overkill.
Depends how right you want something to look. If you stop at smearing duraglass and get some Napa sortamatch paint it can be done cheap.....if you want it dead on looking like came from the assembly line like that, 250$ is a fair price. Here at my shop I'd probably charge anywhere from 150 - 250, depending if you wanted a perfect OEM matched paint and texture or if something very close is acceptable.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old 11-10-2008 | 03:42 PM
my price was for factory fit/finish and radio install.
Old 11-10-2008 | 04:49 PM
MCOR's Avatar
Luke81 is right on but beat me to it. But, it can be done for under $100 on a lot of the I35's if you want just something that is acceptable. It has the same hole as the Maxima's with the Bose/Comfort setup. for those on a budget, we have just trimmed it out, beveled the edge with a triangle palm sander, and sprayed it with trim paint that is very close to the factory finish.
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
