Big 3 Installed for Kyleisme
Old 11-12-2008 | 07:36 PM
Kyleisme's Avatar
Originally Posted by mikiemike75
looks like a pretty descent install but you may want to check into that fuse connection looks like it has some bare wires around the plastic cover... also something good to invest in witch is cheap would be a circut breaker and a battery isolator both can be got for about 50 and help alot... not really the circut breaker but the isolator does if running boom and a 2nd battery...
There is hardly any .. its barely even visible.. only have one battery as if now so neither of those is necessary..
Old 11-12-2008 | 07:40 PM
NT_Hardcore's Avatar
bassheadsent.net
i need this done but ill end up putting it off a few months...
http://www.bassheadsent.net/
Old 11-12-2008 | 07:49 PM
Kyleisme's Avatar
if you have the wire.. Do it.. Its easy as hell.. If i had the tools i woulda done it myself..
Old 11-12-2008 | 07:56 PM
the727kid's Avatar
Glad to hear it helped the voltage so much. A second battery (or alt) should really help on long term bumping.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
Old 11-12-2008 | 08:00 PM
Kyleisme's Avatar
Oh i plan on it.. my battery now is only 530cca and 660ca.. which.. i mean isnt bad but it isnt great..
Old 11-12-2008 | 09:33 PM
94grandcheroke's Avatar
Aka Barry Madikiner
I think you would be good with the smaller Stinger SPV, I believe its SPV44. Only time we ever run the optima's is when were replacing the battery under the hood or adding a battery under the hood. Any other time its stinger or kinetik.
If you dont have the cash to drop on a brand new aftermarket alternator then check out some other models of your car, sometimes a higher model will have a higher output alternator.
Originally Posted by zzz
who gives a fuck its lazer beemz pew pew
Jailbreak and Unlock any firmware for iphone!!! Including 3G phones as well!!!! PM for pricing!
"BOUGHT NOT BROKE" Crew Member# Originator
M.A.S.H. FTW!!!!
Marion Ch. Member #003
Old 11-12-2008 | 09:40 PM
  #17 (permalink)
Kyleisme's Avatar
I want to replace my under the hood battery.. so optima yellow top would be the best option for that? i want to do one at a time to see what helps/doesn't..
Old 11-12-2008 | 10:32 PM
  #18 (permalink)
Notladstyle's Avatar
King of Ricers
Always good to see big3 pics - its the cheapest upgrade for getting more power through the charging system.
However 0/0 is way overkill for a stock alternator. the terminals and fuse connectors are difficult to stuff all that copper into and look bad. ultimately there isn't any benefit to it.
I beg to differ on the corroding terminals though - ive had the same terminals he used on my car since 04 and they look pristine. As long as you charge the battery regularly it shouldn't corrode.
5/2004 stock acdelco battery:
6/2006 optima redtop:
notladstyle.blogspot.com
Old 11-13-2008 | 06:09 AM
  #19 (permalink)
Simek4life's Avatar
Nice work Adrian
Car: 2000 Toyota 4Runner
Head unit: Kenwood eXcelon DNX8120
Components: Boston Acoustic Z6's
Components Amp: Kicker zx850.4
Subwoofers: (2) 15" FI BL's
Subwoofers Amps: (2) Kicker zx1500.1's
Wiring: Knuconceptz (4 Runs of 0/1, (2 pos, 2 neg)
Sound Deadening: Raamat (125 sq ft)
Batteries: Kinetic HC1800; 2 Kinetic HC2400's
HO Alternator: Mean Green ~220 Amp
149.2 db's on TL, sealed, at the dash, bassrace
Old 11-13-2008 | 06:11 AM
  #20 (permalink)
Simek4life's Avatar
I would not waste my time with the big 3 without doing 0/1 gauge... Overkill never hurts especially for upgrades.
