ran into some problems on 98 civic
alright so a friend wanted to put a cd player in her civic so i put on in it. then ran into the problem of the factory alarm that is run through the factory radio. as of right now i just pulled the fuses out of the alarm. is there any way to bypass the factory radio so she can still use her alarm? when the fuses are in the alarm arms when the doors are locked manually the key pad will not work. but there is not a way to disarm it when it gets set off. the car is a 98 civic ex coupe bone stock. i know there are a bunch of eks floating around tr someone had to run into the same problem.
It's likely her dome light also stopped working when the radio was removed. There is a relocation harness that lets you plug in the stock radio, drop it down into the dash straight below there it sits now, and also hook up your aftermarket radio. I don't have it here, but I can have it tomorrow morning. $12 bucks.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Luke
Audio Expert
727-573-2626
Why be cheap and do it without? Using the harness you can wire it all up outside of the car and just plug it in, and be done in 15 minutes, and then uninstall it and put it stock just as quick. Soldering wires inside a dash is not fun.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
The easiest and most straight forward bypass is to wire a cheap aftermarket alarm into the security module and use that to arm/disarm the stock alarm and unlock the doors.
You can also just rewire the security module under the dash to fool it into thinking the radio is there.
I have done it everyway mentioned above over the years. The cheapest/hassle free way for the average DIY'er to accomplish it is as luke_81 states, install the tee-harness. This can be done in less than 15 minutes since you already wired in the aftermarket HU. Unless you hacked off the factory wire harness connector. Did you pay the $3 for the interface or did you cut-n-splice? If you hacked off the factory connector, you will have to take one of the other options listed above...
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
That picture doesn't look like it. The second connector seems a few wires short. The one we have used in the past is made by Metra and is a 70-1720T part number as follows:
Metra Electronics Corp. 70-1720T
Civic 1996-98 - Into Car Allowing Keyless Entry
Although Metra's picture is incorrect.
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
