yeah it is.. not super rounded but its the best i could do
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
Well since you decided never to post again I don't have to remind you that fiberglass mat is weakest when formed perfectly flat. It adds absolutely nothing to the strength of the box =(
and for the second time, enclosure fail
Damn you guys don't give this guy a break. I must say the build quality on the box is pretty impressive coming from him. And otherwise some of you are giving him shit for no reason. There is nothing wrong at all with 2 subs in a single chamber ported, hell I have built tons of boxes like that, and seen 100s more like it. In fact it is easier, smarter, and just overall better really do it like that. As for the size of the box, 4.4 doesn't seem to big. Hell given the amp that is being used, it is probally smart to make the box that big. It's going to allow the subs to much more effieicent, so a ton of power won't be neccesary.
Need anything installed or built? PM me.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Tweets: Image Dyamics CD1pro mini horns
Mids: Sundown Neo Pro 8s
Amp: Kicker IX500.4 (2)
Sub Stage
Subs: (2) Dayton Audio 15" HF
Amp: Kicker IX1000.1
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
by the way (1stgen7) the box dose look good ...you are actually improving in build quality. For your previous post, don't delete post cause of criticizing, you have to take the good with the bad if your going to post your work....
Originally Posted by George Orwell 1984
Its presupposed that somewhere or other, outside oneself, there was a "real" world where "real" things happened. But how could there be such a world? What knowledge have we of anything, save through our own mind? All happenings are in the mind. What ever happens in all minds, truly happens.
Originally Posted by Funk
Your mind contains the whole universe, the key is being able to see past yourself, this world, and thought itself.
Nothing wrong with a shared chamber in a ported enclosure...oh really?
I was thinking the same thing...
Matt-check out these deals: https://www.tamparacing.com/forums/m...ood-stuff.html
MCOR Automotive LLC
mcorautomotivellc@verizon.net
www.mcorautomotive.com
1635 Dale Mabry Hwy Ste 3
Lutz, FL 33548
(813) 362-5454
"TR Official 12V Shop"- Automotive Audio/Video/Security (JL Audio, Alpine, Hertz/Audiosn, ARC Audio), Window/Tail Lamp Tint, Custom Wheels, Clear Shield, automotive upholstery and leather conversions, "All the Above!"
MCOR Automotive LLC
Lutz, FL 33548
(813) 362-5454
Care to tell me what's wrong with it?
The only problem that even comes to mind is if one sub is too close to the port and it begins unloading, but sub placement would correct that.
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
Most subwoofers are designed to use air resistance to augment the subwoofer suspension.
no air resistance = no transients and very bad sounding music. especially with a low power amp.
thats why ported boxes "unload" at frequencies below their tune point - the air isnt moving fast enough to produce any back pressure on the subwoofer.
good build from the pics. does it sound good? as long as it does thats all that matters- i built a similar box for 2 of my 12's and it sounded great...
http://www.bassheadsent.net/
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
MECP Certified.
Alarm: Viper 5200
HU: Stock
Active Set-Up
Sub Stage
