audio help
Old 01-18-2010 | 10:23 AM
jhimely23's Avatar
Default audio help
hey im trying to run to amplifiers in my car. i ran all the wires correct for both amps. i bridged the front speakers behind the radio with the rear ones. but when i tried turning it on and it sounds like it doesnt have any signal... i wanna know if i did it right. front right + with rear right +, and front right - with rear right -. and the same thing in the other side... i wanna know if thats the correct way of running it.. need help asap plz.. im goin crazy lol
Old 01-18-2010 | 10:42 AM
alphabets's Avatar
I ♥ ♫
Uhm, what? Are you trying to run two amplifiers? What do you mean you bridged the speakers behind the radio? If you're running amplifiers, you need to have your RCAs running out of your headunit, to your amps, then your speakers hooked up to your amps.
Try being a little more clear in your next post, it'll make this whole process easier.
lol, internet.
Old 01-18-2010 | 10:45 AM
NT_Hardcore's Avatar
bassheadsent.net
i think you have done something wrong. need more info and/or pics pls
http://www.bassheadsent.net/
Old 01-18-2010 | 10:56 AM
jhimely23's Avatar
ok. how would you run two amplifiers.? ok i ran one straight power wire from the battery. i have two grounds coming from the chasis. the remote is split to boths amps. both the amps two on with no problem. its just the highs. i ran the speaker wires how i said in the last post. i connected the front tothe back ones. and from the back ones to the amp. and it gives me a static noise. how could i fix it
Old 01-18-2010 | 11:01 AM
bassheadsent.net
what are you running off these amps? and are you using the wires from the head unit instead of rca's?
Old 01-18-2010 | 11:05 AM
GradeA_TireFryer's Avatar
All American, rice eater!
nt did you puckup that 3000d i sent you a link to?
and to OP i can look at this if you want?
Old 01-18-2010 | 11:07 AM
bassheadsent.net
i have not yet, changing subs first.
Old 01-18-2010 | 11:09 AM
what subs? need another box? I got a deal on thoses EXILE 15's or 18's!!
Exile Audio
Old 01-18-2010 | 11:11 AM
jhimely23's Avatar
naw i didnt get the link
Old 01-18-2010 | 11:15 AM
bassheadsent.net
im looking into a custom pair of FI's as of right now. if it falls thru id b interested in the 18's ! OP what are the speaker wires off the head unit going to? and are you using rca's? what are the 2 amps powering?
