build.
Old 07-19-2010 | 11:09 AM
luke81's Avatar
For sure, dude you're coming a LONG way from the first stuff you posted up. Keep it up, and be proud of what you're doing.
Luke
Audio Expert
11203 49th St. North Unit A3
727-573-2626
www.audioexpertonline.com
Audio Expert's Facebook site
Old 07-19-2010 | 12:29 PM
NT_Hardcore's Avatar
bassheadsent.net
but remember your never done learning
http://www.bassheadsent.net/
Old 07-19-2010 | 12:40 PM
GradeA_TireFryer's Avatar
All American, rice eater!
Talking
but he should of measured so they would fit
Old 07-19-2010 | 01:29 PM
bassheadsent.net
yea build quality was rly good, but it kinda fell apart on the instal side. live and learn-
Old 07-20-2010 | 07:45 AM
wait till you all see the mess i am working on now, complete gut...... system was installed less than 2 weeks ago. one of the worse i ever saw, BYC you could not even have done this shitty of work.
Every single thing was done wrong, not one correct item.
under hood, NO fuse on 0 guage to rear batteries, they only had 4 guage connectors so they cut down the wire to fit, smashed and taped, every one pulled out.
thru fire wall looked like a beaver chewed a hole, no gromet nothing,
wiring in dash giant birds nest. front doors, used factory wires connected to crossover that hung so everytime you opened and closed the doors they banged.
rear doors have 2 5 1/4 in them, each suppose to have own crossover, they used one for both. rear deck 6 x9 crossovers hanging,
Now the fun stuff, BOX, build out side car, could not fit in (4 12's) so they cut the car's trunk opening, pealed back metal, pushed box in and rewelded (never in 20 years have i seen this), in box construction they could not cut the speaker opening to get subs to fit, so there was 1/4 to 1/2 of liquid nails under around in on everywhere on the subs, use of wood glue must be a mystery to them, and also predrilling screw holes, as i could pull each panel apart with out tools, open it up and find 2 batteries in the box!
amps we mounted to top of box between subs, the 2 mono amps, only one was hooked up to play, but look like it should, the 2 4 channel amps only 1/2 of each amp used, no it was not bridged, just not hooked up... there are 26 mids/highs in this car. the also wired one amp as the right side and the other the left? there many more mistakes problems, breakage. So i completly took every thing out, rewire front to back, box is being buit in the car, for the 4 12's in 8 cubes tuned to 35hz, with 2 6" aero ports thru rear deck (they just came in they are huge) subs firing back, ported up, batteries were mounted in spare tire well, the 2 4 channels amps & electrontic crossover going on box behind fold down back seats, and the 2 3K mono amps on a floating amp rack in trunk.
i'll take pictures now as it is going back together, i have no idea how loud this will be.
Old 07-20-2010 | 11:36 AM
kpr10is's Avatar
Maximaniac
Those two points are true winners.
Share who originally built it?
Old 07-20-2010 | 11:47 AM
  #17 (permalink)
a guy in brandon trying to start a shop, his name is Ryan,
RUN AWAY, DONT LET HIM EVEN LOOK AT YOUR CAR.
Old 07-20-2010 | 02:57 PM
  #18 (permalink)
bassheadsent.net
hmm im interested in this, shop name lol
Old 07-21-2010 | 07:45 AM
  #19 (permalink)
his shop is called......
Insane Customs
INSANE CUSTOMS - Home - Tampa,, FL
here is how he goit it back
my start of rebuild
Old 07-21-2010 | 08:14 AM
  #20 (permalink)
1stGen7's Avatar
layin frame for life
OMFG i hope he didnt pay for that install. i think my freinds little 13 year old brother could do a better job at installing then that! (not even jokeing his little brother can do some nice work on a install ). why the box faceing the rear? i think faceing the front would be louder?
sub stage. 4 american bass XD 15's
sub amps. 2 audiopipe APSM1500's
mid's. 16 american bass SQ 6.5's 8 pyle pro super tweets
mid's amps. 2 autotek ATX3000.2 and 1 autotek ATX950.4 on the tweets
