Fuel Delivery System
I race sailboats
on
Hello bike tech, Im looking for some advice. I have been charged with the design and implementation of a fuel delivery system for an SAE Formula Hybrid car, and I was hoping someone here could point me in the right direction.
The car utilizes a 2005 Kawasaki EX250 engine, completely unmodified, and we will be running twin 40mm carbs with velocity stacks. We are trying to run the engine as lean as can be done safely(along with twin radiators to help with cooling lost by the use of less fuel), as the competition is for Hybrids, and fuel use counts big for points. We need a very low flowing fuel pump, preferably an inline pump, that would exert very little draw on the vehicles capacitors, and would be compact enough to fit into the limited space we're working with.
Good links/tips/advice = reps.
Sponsorship is also an option, give us a fuel pump/donations, we can put your name on the car.
Look at the old Hayabusa external fuel pumps. They are faily small and can be mounted anywhere along the fuel line. As for flow, it's probably more then what you prefer, but if you use a PC3 you should be able to lean it out pretty well running fuel injection.
Do you really have to start a thread every time you go on a ride and see a guy with no helmet on?
Does it affect you that much that some random guy 1500 miles away went and paid his own money for a 1000?
Do we really have to fight over who uses the back brake or not?
Do you have to argue over stupid pointless shit on the Internet?
ELECTRIC FUEL PUMPS 12- VOLT
check out p74021
you could also run an oil cooler along with colder burning plugs to keep temp down.
check out p74021
I race sailboats
on
Thanks for the link, i'll bring up the oil cooler/plugs idea at the next meeting.
look at the NOS fuel pumps they are inline,
Holley Performance Products Low Pressure Fuel Pump 15760NOS low volume and pressure....
-TK
If you can Turn you are not going Fast Enough!
-TK
Originally Posted by Raybo
I'm not a loser, I'm just incarcerated.
Originally Posted by Treysdad
Tell me about it. Sometimes i get this abrasion just under the head, liek a friction rash. All day it will feel like there is a Mexican midget in my boxers licking it with a cats tongue.
