ninja 636 shifting problem
Explain a little better, bc this sounds its doing what its suppose to... One click is one gear change, teach her to downshift properly bc coming to a complete stop in any gear above 2nd is going to make it difficult to downshift to first. None of the bikes I have ridden do this, the output shaft is not spinning and the transmission gets to the point that the dogs can't engage properly and if she keeps on trying she will Fuck the transmission up...
this...
just change the oil and down shift while still rolling to a stop, not once stopped. kawi's beat up oil quick and shifting gets notchy. i do mine every 1500 miles or so.
as for car oil, yes some are bad, but rotella syn is fine, i've used it in my 10 since new. cheap and works fine. i've also tried some over priced motorcycle oil just to see if it might shift smoother for longer and it doesn't. it got worse faster, so i gave up and just use whats cheap and works.
