2 kenwood 10inch subs & Kenwood amp
80 for the amp
Last edited by Notladstyle; 03-05-2007 at 03:29 PM. Reason: cheaper than i thought
The Kenwood KAC-7202 2 channel Power Amplifier features a die cast aluminum heat sink, detachable aluminum dress plate & top panel cover, variable bass boost, built-in low and high pass filter, RCA inputs and outputs, speaker level input, cooling fan, power MOSFET switching power supply.
Specs:
* 4 Ohm @ 14.4V = 150W x 2
* 2 Ohm @ 14.4V = 230W x 2
* Bridged @ 14.4V = 460W x 1
Max Output power: 920 Watt Retail is $249.00
About the two 10 inch Kenwood subs i have no info on it but im sure you guys know more about it then i do.
Throw me some prices.
Specs:
and you can buy that amp anywhere for 150... its probably worth 80 since its been used for a while, which is a good deal on both ends.
