NASCAR Reducing grip for 2017 how they are doing it.
[h=2]NASCAR: Michigan is last chance to test 2017 rules[/h] Friday, 26 August 2016
Matt Weaver / Images by LAT
For the second time this season, NASCAR Sprint Cup teams unloaded at Michigan International Speedway and were greeted by the proposed 2017 rules package.
The sanctioning body first ordered a reduction of downforce last season after a decade spent increasing it and reducing overall horsepower. These regulations have built upon the success of the 2016 campaign and have reduced the rear spoiler from 3.5 inches high to 2.5 inches.
The width of the spoiler has also been reduced in width from 61 inches to 53 with the inclusion of a deck lid fin. NASCAR has also decreased the length of the underside of the front splitter by about three inches and eliminated rear skew – the angle of the rear-end housing that aids rotation in the center of a corner while generating side force.
League officials had actually considered returning to Michigan with the standard 2016 package but ultimately chose to use the same rules used back in June.
For this weekend, the changes mean drivers will enter the corners with increased speed from last season (nearly 220mph) while also having to lift off the throttle to make it through to the other side. This makes the cars unstable – and that's good for the long-term improvement of the racing product, according to Brad Keselowski.
"The cars are very loose," Keselowski said. "They are very difficult to drive and they should be. That causes a lot of wiggles and bobbles, all those things on the racetrack that tend to lead to a lot of excitement. Hopefully, more than anything, it gets the cars to where we can run closer and tighter as a pack and have even more passing."
But not only are drivers lifting in the corners this weekend, they're having to use the brakes more than they have in years, according to Austin Dillon.
"With this package, you carry a lot more into the corner and have to back it up with the brake pedals," Dillon explained. "The bigger brake packages you see out there, that's going to be a part of the race and keeping your brakes good.
"At Michigan, you can roll the corner and lift early, so that's not a big deal, but the shorter tracks could make it become a huge deal."
It's important for NASCAR and the teams to test this package one more time because it won't be used during the Chase for the Championship – the most important stretch of the season. Additionally, Goodyear would like one more race day environment to help the tire maker prepare for 2017 as well.
Jonathan Merryman and NASCAR's Senior Vice President of Innovation and Racing Development, Gene Stefanyshyn, break down in detail, some of the visible changes fans will see on track in 2017.
https://www.youtube.com/watch?v=CZnHgsG9niE
[h=2]Speed Limit[/h] Tom Jensen
Back in the day, NASCAR founder Bill France Sr. saw speed as a way of putting stock car racing on the map. Now, miles per hour is just one aspect of the sport's optimal package.
Carl Edwards climbed out of his car and shook his head as he talked to reporters at Michigan International Speedway. It was August 2014, and Edwards had just posted a qualifying lap of 206.115mph.
Astonishingly, that didn't put Edwards on the pole for the Pure Michigan 400. In fact, it didn't even put him on the front row. Jeff Gordon took the pole with a track record speed of 206.558mph, just ahead of Joey Logano's 206.381mph. All told, 32 of the 43 cars that made qualifying attempts smashed the 200mph barrier.
"It's fast. That's the simplest way to describe it," Edwards said, disbelief etched on his face. "It's fast. I wish you guys could ride in that car with me. That is screamin'..."
Speed matters. NASCAR founder William Henry Getty France knew as much. Speed was a huge motivator behind France's creation of, first, Daytona International Speedway in 1959, and then Talladega Superspeedway a decade later.
In the mid-1950s. Indianapolis Motor Speedway was the epicenter of auto racing in the United States and NASCAR was a relatively small, regional player compared to the "big car" open-wheel races put on at the Brickyard and elsewhere.
So France reasoned that building a high-banked, 2.5-mile oval would put stock cars closer in speed to the open-wheel boys running on the essentially flat IMS track. In his biography of France, "Big Bill, The Life And Times of NASCAR Founder Bill France Sr.," Herb Branham wrote that France's vision for Daytona was "a design that would allow stock cars to chase unprecedented speeds."
Those heady post-World War II days were a time of enormous optimism in the United States and a time where barriers were being broken everywhere – on racetracks, with ever-faster street cars, jet airplanes and even the early days of the space race. So building the nation's fastest oval was in tune with the zeitgeist.
A decade after opening his Floridian temple of speed, France opened an even bigger and faster track, the 2.66-mile Alabama International Motor Speedway, known today as Talladega Superspeedway.
At Talladega, the pursuit of ever-higher speeds continued unabated for almost two decades after the first race in 1969. On April 30, 1987, Bill Elliott set the all-time NASCAR qualifying record of 212.809mph there. And Elliott's lap was nearly as fast as that year's Indy 500 pole, set by Bobby Rahal at 216.609mph.
But in the May 3 race at 'Dega, Bobby Allison cut a tire and his Buick got airborne, hurtling into the catchfence and tearing nearly 1,000 feet of it down. Miraculously, there were only minor injuries, but NASCAR immediately took steps to slow the cars down and even now periodically tweaks the rules to limit lap speeds at Daytona and Talladega to no more than 200mph.
France built those two superspeedways to play catch-up to Indy. But thanks to the disastrous CART IRL split in the mid-1990s and a host of other factors, NASCAR has long since blown by Indy car racing in terms of popularity. And its approach to speed today is much, much different than when "Big Bill" was chasing his dream.
"Obviously, it's racing, so speed is very important to us and generally the more, the better," says Gene Stefanyshyn, NASCAR's vice president, innovation and racing development. "But we're not going to optimize everything for the sake of speed. Think of it like a triangle: There's speed, there's the entertainment for the fans and then there's safety."
To that end, in each successive season since 2013, NASCAR has introduced a different aerodynamic package designed to make the racing more competitive, although not necessarily faster...
TRack Events Forum
05-29-2014 08:46 AM
Toniek9
4 Lug Wheels For Sale
11
04-21-2014 12:52 PM
