some pics of my project, 56k...probably not
![Default](https://www.tamparacing.com/forums/images/icons/icon1.gif)
Originally Posted by GsEclipse02
i know u said srt4 but is that a srt4 motor ..... or a dodge stratus motor?
Looks good Josiah. What turbo is it?
2004 Flame Red Dodge SRT-4 - 1 or 2 mods
2007 Bright Silver Metallic Dodge Nitro - Stock
Peon on steroids!
on
its an SRT4 motor....stock internally, with my hahn 20g, the TB is actually my modified stock 49mm TB from my 98 since it bolted up and I didnt feel like buying an SRT4 one just yet, as you notice with my wiring, this is being run from a standalone(hence no MAP sensor in the manifold, I tapped it for a GM MAT sensor instead) and some of you may be interested to know that the fuel rail is from a 96 SOHC car, bolts right up with some nuts used as spacers
damn Josiah, havent heard from you in awhile. your making alot of progress. hit me up man. id like to see it.
![](http://i63.photobucket.com/albums/h133/LS1Fever/Kevin%20RIP/restinpeace.jpg)
![](http://i63.photobucket.com/albums/h133/LS1Fever/Kevin%20RIP/kevRIP.jpg)
![](http://i63.photobucket.com/albums/h133/LS1Fever/Kevin%20RIP/pablo.jpg)
Peon on steroids!
on
yeah, my built '96 2.4 decided to spin a rod bearing(bad judgement when originally assembling it, I decided I didnt need a new crank because of a small scratch on one of the rod journals...I was wrong....anyway, this motor is to replace the 96 while I tear it down and rebuild it, then I will probably end up swapping the '96 2.4 engine into my '95 neon, but once I get this thing fired up and driveable I'll be by to see you with it(currently need to get my trigger wheel mounted on the pulley and some I/C stuff finished, then I should be set to go
Does the 96 SOHC rail have a schrader valve on it and how does the size compare to the SRT stock rail?
Peon on steroids!
on
yes, the SOHC has a schrader valve on it(my FPR is connected to it via the SS line in the picture) as far as size vs the SRT rail...no clue, large enough to support 500HP though so I dont much care, since this block will never see more than that anyway
