I was able to fix it by using the Tap tool! Thank you so much for the input!
5.7Clo Discussion starter
13 posts · Joined 2023 I was changing out my thermostat and the screw to the left isn’t screwing back in for some reason? I didn’t want to strip the holes as they connect to my water pump. The other one is fine and can screw in properly but this one isn’t for some reason. I had screwed it in at a weird angle at first but then stopped once I realized it wasn’t going in easily. Any tips or ideas would be great thanks
Save Share
Reply Like
Sort by Oldest first
NJMOPAR
1181 posts · Joined 2021
Looks like the first 5 or 6 threads are galled from going in crooked.
Might be able to chase it with a tap.
Clean it out with a pick first, the grey clumps almost look like rtv sealant.
Save Share
Reply Like
Thank u so much i will try that!Save Share
Reply Like
NJMOPAR
1181 posts · Joined 2021 #4 · 4d ago
Use the other bolt to get the correct tap size. Work slow, aluminum is soft.
Canned air to blow out the shavings.
Save Share
Reply Like
13 posts · Joined 2023 #5 · 3d ago
Just to update.
I was able to fix it by using the Tap tool! Thank you so much for the input! It was very helpful.
Save Share
Reply Like
NJMOPAR
- [img]data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7[/img]
Save Share
Reply Like
Reply Like
NJMOPAR
Save Share
Reply Like
Just to update.
American Iron Tech
01-24-2024 06:24 PM
