Drag Racing Don't like turns? Tech talk about drag racing and drag event discussions here
Alum flywheel vs Steel flywheel debate let's hear it
Old 12-12-2003 | 10:22 PM
bitemark46's Avatar
Got traction?
Default Alum flywheel vs Steel flywheel debate let's hear it
I used to have a steel which was great on the launches but trying to save my tranny I went with a alum flywheel. I know in drag racing you need enrtia(sp?) but heres my question:
If your able to get the car to 60ft the same then the alum flywheel will allow the rpms to climb faster due to less rotating mass right? But if you shift slow then the rpms drop faster. Let me know your thoughts between the two FW. Thanks. -Mark
98' cobra
Old 12-13-2003 | 07:13 AM
Strokd85's Avatar
Daddy-O
I would only use an alum. flywheel in a high rpm combination (like my old S/B combo). Those types of combinations are all about lightweight components (rotating mass, valvetrain, trans/gears, etc) and they're geared up enough that getting the car to 60' isn't an issue. JUst my $.02 though.
I am your penalty.....
Old 12-23-2003 | 10:26 AM
race495's Avatar
Pull Over
Also works great with a blower combo due to allowing the motor to rev faster which brings in boost faster. 60 ft may or may not suffer depending on torque output and launch rpm.
"I'm in the 82nd Airborne and this is as far as the bastards are going!"
93 Cobra, R302 331,canfields,T-76,TKO......sold
87 Coupe, 466, Edelbrock heads,Vic jr,150 shot 10.41@129.5...sold
2006 Honda 450ER .....new toy
Do you own a Torch Red FRC and tremble every time you drive under I75 on Hwy 60 and look in your rearview mirror? If so you are suffering from what is known as Cobraphobia.
Old 12-29-2003 | 07:32 PM
Strokd85's Avatar
Daddy-O
I was coming out of the hole at 6k. so it never really affected me..
Old 12-29-2003 | 08:58 PM
bitemark46's Avatar
Got traction?
I'm thinking that my first time out with the alum FW my et was so off cause I was over reving the car. I hit the limiter on the 1/2 and 2/3 shift. The tach used to be off alittle. I would shift at 7k and not hit the limiter. Now that tach is right on the money. Everytime I got the needle 1 pubic hair above 7k I tapped the limiter. I think I'll try 6800 and see what happens. -Mark
98' cobra
Old 01-14-2004 | 03:05 PM
Plopokiller's Avatar
HoHo's
Aluminum flywheels are 2 peices, the ring gear breaks off when the center is too hot. If you go with aluminum its not gonna be a daily driver. Also you should loss torque. Torque = rotating mass.
2640lb.
227.5 RWHP
Old 01-14-2004 | 03:07 PM
HoHo's
Try billet steel my .02 cents
2640lb.
227.5 RWHP
Old 01-14-2004 | 07:32 PM
Mr 2's Avatar
New Member
OK
Old 01-14-2004 | 08:09 PM
bitemark46's Avatar
Got traction?
Don't you mean rotating mass/heavy flywheel = enertia(sp?) A heavy rotating mass will give the sense of torque cause once the flywheel gives the tranny all that energy/power, the tranny passes it to the tires. That's why I would have to raise my launch rpms to equal the same 60ft. But once I achieve that, my car will accerlate faster due to less rotating mass for the motor to turn. My car is a daily driver. It's drives fine. I can get away with it cause my car is geared like a mofo! -Mark
98' cobra
