Advice pls
Advice pls
I have a 90 5.0 and i think the fuel pump has gone bad. I let the car sit for a while and now I am not getting any pressure to the fuel lines. Does anyone know an easy way to test to see if the fuel pump is working?
put ur head to the bottom of the tank, have some1 turn on the key. if u dont hear it whine, then u have ur answer. lol
TurboRAM Member #5
24psi & Stable
GET SOME
That or unplug the incoming fuel line from the fuel rail and turn the key on. If fuel shoots out then pump is working.
Many reasons to prevent the fuel pump from working. Fuel relay,.. clogged screen,.. clogged pump,.. pump mechanical failure,. computer relay failed causing fuel pump relay to fail,.. I'm sure there are a dozen more.
If the pump indeed isnt coming on,.. there is a test harness under the hood in front of the driver side hood hinge. I dont remember exactly which port is for the fuel pump,.. but if you short out that particular port with the test wire,.. its supposed to force the fuel pump on in the event that the fuel pump relay had failed.
Hurst
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Don't forget the Inertia Switch ...
The '87 Coupe to be built and raced in our son's memory.
Cameron Lee Koss - 9.1.1991 - 8.05.2011
I can do great things when not experiencing "Man-A-Pause" StangItMan '08
if you hear the pump run when the key gets turned on and it still doesn't run check the canister filter back by the tank. It is mounted in front of the tank and looks like a small coffee can. If it is clogged it won't let the car run or it will run for a minute and shut off depending on how clogged it is. It is about 15.00 easy to replace and could be your problem.
God bless America!
God bless our troops!
God bless the GOP!
God bless America!
God bless the GOP!
