bought a '99 Cobra 2day.....
Old 11-25-2003, 11:46 AM
  #51 (permalink)
boostmonkey
craig_302's Avatar
Originally posted by URFUCT
It doesnt have one Craig, I'll go ahead and buy it from you, how much did that custom induction piece cost you?
I got it for 50 bucks off of Jeff when he was parting out his 01. I think it was 50, maybe it was 100. I really don't remember. Either way, I got it for a good deal.
Old 11-26-2003, 11:27 PM
  #52 (permalink)
car with tiny wheels
CBRTRX's Avatar
HA WILL, IVE MET U BEFORE I HAVE A BLACK 03 COBRA. I CAN TELL YOU A MAJOR PROBLEM WITH THE COBRA IS THE IRS WEIGHT AND WHEELHOP. LOWER GEARS MAKE IT MUCH WORST. THE BEST IS TO SWAP TO A SOLID AXLE WITH 373 RATIO. PUTTING LOWER RATIOS IS NOT NEEDED TRUST ME. THE IRS WILL SNAP HALFSHAFTS AND BLOW A HOLE IN YOUR REAR CASE WITH LOW GEARS AND DRAG RADIALS IVE SEEN IT. THE 4V MOTOR RESPONDS WELL TO INTAKE AND EXAUST MODS MUCH BETTER THEN 2V MOTOR. IF YOU REALLY WANT TO BE FAST AND RELIABLE THEN GO TO SOLID AXLE AND SAVE WEIGHT TOO. SUB FRAME CONNECTORS ON THAT CAR HELP WHEEL HOP SO DO LOWING SPRINGS, BECAUSE THEY PUT THE AXLES MORE LEVEL AND THE LOAD IS MORE EQUALLY PLACED, JUST BE CAREFULL HOW HARD YOU LAUNCH WITH DR's. I HOPE THIS STUFF HELPS.
in memory of Kevin Gonzalez 6/21/86 - 9/13/06
Old 11-27-2003, 06:53 AM
  #53 (permalink)
TR Balla Donor Supreme
98MODMTR's Avatar
"The problem with socialism is that you eventually run out of other peoples' money." Margaret Thatcher
Old 11-27-2003, 11:07 PM
  #55 (permalink)
Y2JAY's Avatar
Is your 03 black? I just put the off-road x-pipe on with flowmasters and the tri-ax shifter, it sounds pretty badass!!! I need someone to do my springs now...
ya its the 1 u raced
