will a 85 down water pump fit a 87-93 motor????
change cars like socks
will a 80-85 5.0 water pump fit a 87-93 5.0 mustang motor??????? what i am trying to do is i have a 87-93 5.0 motor with reverse flow water and its got a v-belt system on there and its running the water backwards if i put a 85 and down standard rotation water pump it will run the right way without having the change the belt setup
Advance Auto Parts ASC WP641 standard rotation
or NAPA 55-4052 standard rotation.
Housing is the same as reverse rotation pump and made for serpentine belts. You will need to clearance your water pump pulley holes for the bolts.
1993 Cobra water pump pulley, WP641 STANDARD ROTATION WATER PUMP (or NAPA 55-4052 ), underdrive crankshaft pulley, 3G alternator on stock alternator bracket, Dayco Poly Cog 5060450, $22.88 at Advance Auto Parts (you might end up using 5060445 / 6PK1130 if it needs to be ½ inch shorter).
Difference between the standard and reverse rotation impellars.
STANDARD
REVERSE
STANDARD
REVERSE
Helmut
Helmut
Originally Posted by LSVTEC89HATCH
thanks for those pics and part numbers your a life saver ...but i like the 86 gt nose capris have ugly noses
no taste, carpris are the bomb.
