Update for the followers
on
What exactly are the IAC and ACT sensors? It would actually help if someone could list most or all of them so i can eliminate them as a problem
The TPS sensor was brand new it came on the throttle body...
BTW Stewart Scott thanks for the instruction sheet, much appreciated
Idle Air Control(on the side of the throttle body) keeps idle when the throttle body is shut. Air Charge Temp (drivers side of the lower intake around the number 3 runner) senses temp of air when going into the engine. O2's are for the exhaust(they are in the h pipe and reads oxygen in the exhaust). TPS needs to be set anywhere from .80. volts to .98 volts. It's a learning curve but you will get it, I have faith in ya....
God bless America!
God bless our troops!
God bless the GOP!
God bless America!
God bless the GOP!
