Update for the followers
Old 01-22-2006, 06:15 PM
86stang's Avatar
Default Update for the followers
We messed with the timing for about 3 days, and determined that its not the distributor or coil thats causing our problem.
You see, the car "runs" the best when we set the timing completely out of whack, and when we try to set it the way its supposed to be, it barely even starts. Is there any particular reason why this would be happening you guys?
We checked all the plugs and they are all hooked up correctly...
Any suggestions?
Old 01-22-2006, 09:15 PM
evocrazy1's Avatar
timing could be 180 of
ASKED TO BE BANNED
Old 01-22-2006, 09:26 PM
TR Balla Donor Supreme
shinysideup's Avatar
balancer ring spun and no longer starts TDC in the correct location?
Old 01-23-2006, 02:53 AM
"Now I only have two"
Stewart Scott's Avatar
timing chain worn or cam and crank not lined up correctly?
Tell us what it does when you say it "runs". Does it run like you could drive it or is it barely staying alive?
I like the suggestion Joe gave with the balancer ring spinning. Does the old balancer look a little out of shape, the rubber ring will be un even, maybe sticking out a little. It will give you different position on the timing marks if it has spun.
Sorry ot hear about your problems on this car....hope you get it running right...
God bless America!
God bless our troops!
God bless the GOP!
Old 01-23-2006, 03:48 AM
86stang's Avatar
Timing chain is brand new, and cam and crank not being aligned correctly could be the issue, although I doubt it seeing as me and my mechanic made a specific point to set that correctly. The balancer could be screwed, Ill check into that as well.
Going to grab a new computer today, mine has 0 TPS voltage and with your instruction sheet you fax to me ill check the connections on the connector as well.
Old 01-23-2006, 10:53 AM
ok.....what is your fax number?
God bless America!
God bless the GOP!
Old 01-23-2006, 10:56 AM
nevermind I got it in the other thread, sorry, will fax it now...
God bless America!
God bless the GOP!
Old 01-25-2006, 02:58 AM
86stang's Avatar
Ok guys we actually got to drive it tonight, after the new computer was installed it idles and doesnt shut off...but its definantly not a good idle...
We put some new sparkplugs in it and went around the corner in it and it is running very flat and is backfiring just a little, not to much...
The mass air meter I bought was used and previously been in contact with nitrous (when i bought it there was a hole where the jet was) and im thinking this might solve our problems for good. Its good to drive her down the street again though, been a long time coming
Old 01-25-2006, 05:17 PM
Glad to hear it..now you have all those other sensers to check like the TPS, IAC, ACT, O2, etc...yippee
God bless America!
God bless the GOP!
