Water pump
Old 10-22-2008, 11:03 AM
Made Of Scars
byondevl's Avatar
Default Water pump
ANy benefit to spending the extra $$$ for an electrical pump? HP loss seems minimal with the mechanical
Old 10-22-2008, 01:36 PM
Flowmaster nut swinger
Na306StAnG's Avatar
I know a couple people that swear by them, but I've never owned one and see no need for one. Unless your trying to remove weight from your wallet
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old 10-22-2008, 02:24 PM
Redneck Yatchclub member
Shamus O'Toole's Avatar
Agreed! The one place the i see a benefit is when your running a front mount single turbo. Not having that belt in the way is a plus.
Old 10-22-2008, 04:50 PM
Bondsman
GNs-r-slow's Avatar
Another benefit is that you can run the pump and fans and cool the car down between rounds.
Old 10-22-2008, 06:41 PM
Made Of Scars
byondevl's Avatar
That is true, that I didn't think of.
Old 10-22-2008, 07:03 PM
Na306StAnG's Avatar
Is this going to be a track only car?
Largo fl 33773
MV#72427
Old 10-22-2008, 08:19 PM
Made Of Scars
byondevl's Avatar
I think this thing is to big of a pos to ever see the road again. It may see the occasional meet or something. My cleveland probably isnt the most streetable engine anyhow.
Old 10-23-2008, 01:27 AM
has his prioritys ef'd up
BigDawg's Avatar
Some sanctioning bodies will not allow that, actually.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old 10-23-2008, 04:33 AM
Na306StAnG's Avatar
Is the motor high compression? If you for see a cooling problem is possible then it might not be a bad idea.
Largo fl 33773
MV#72427
Old 10-23-2008, 05:33 AM
Got traction?
bitemark46's Avatar
They flow like a muthafukka. With a stock t-stat and fan settings my meizere pump lowered my temps a lot. Meizere's site says they are good to around 3000hrs of runtime. I don't think my pump would ever get there lol. Good thing is if you throw a belt you can still get home and not over heat.
-Mark
98' cobra
