To crossover, or not to crossover... That is the question!
/\ My intake... Note the -AN fittings at the rear of the intake... Bought it that way, and not sure if it's necessary to run a crossover line from fitting to fitting, or if I should remove the fittings and plug them.
Discuss. Support theory.
Thanx
since they are there we will use them
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
They definately help balance the temp in all the cyl's, and I have always seen atleast a 15 deg drop in running temp when this is done.....
I'm not sure what you mean by how to measure them? but I usually tee them together and run them up to the heater return nipple on the water pump for recirculation..... If you are using a heater core you can go from the back of the intake to the heater core and then up to the water pump.....
I have done this in braided or in regular heater hose, both work fine.....
not to hijack ur thread josh, i need one of the "T"'s u guys speak of, im runnin an open breather and wen tommy was out to take a look see at it, he advised me to get one. napa? adavnce? autozone? i really dont feel like gettin an expensive one from a hardware store. ne suggestions?
TurboRAM Member #5
24psi & Stable
GET SOME
either -8 or -6 AN
AN Fitting Thread Size Chart
