fuel system 87 efi 5.0
Do any of you guys know where the fuel pump & filter are on an 87 Crown Vic 5.0 efi? It seems as if the car is just not getting enough fuel, turns and turns, but will not kick over...when I spray the TB with starter fluid it starts right up. I was thinking the pump was not cutting on (didn't here it) or that the fuel cutoff switch was activated, but it will run when primed which leads me to think it could be something else...any suggestions?
Why is it when ever I really need to weld something the acetylene always seems to run out...
Only babies drink from bottles...
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
would I here the pump turn on or is it mechanical?
Boosted 00 Si
N/A 93 HB b16/18
Boosted 00 Si
N/A 93 HB b16/18
No it is electric. You should hear it engage with the turn of your key.
"Gripping the wheel his knuckles went white with desire, the wheels of his mustang exploding on the highway like a slug from a .45. True death. 400 horsepower of maximum performance piercing the night, this is Black Sunshine"
Guest
Posts: n/a
You may or may not hear the pump turn on. It depends on if its worn out and how much gas is in the tank. When you turn the key to "run", the pump should run for about 10 seconds. If after that 10 seconds the computer doesn't see an ignition signal, it will not run the pump. What happens sometimes is the TFI module (on the side of the distributor with a big plug in it) goes bad, it will not provide the computer with the ignition signal which will cause the fuel pump to not run. So basically be careful diagnosing this, because what seems like a fuel pump issue may not be.
Whats the story of the car? Has it been sitting? Was it driving and just quit? Help us help you
