Best way to heat bottle w/o bottle warmer
Dude put it over an open FLAME... like a big fire... and make sure you use gas.... no......HOT WATER BRO! heat the sucker up with water
20G (displacement replacement)
Originally posted by TheShow50h
:o
:o
i have a blanket warmer that plug sinto your cigarete lighter, if any of you wanted i will let it go cheap, i also have NOS heater thats for sale in the classifides, and to get a quick fix, the bath with warm water works best, dont torch it, just use your warm water, you do have warm water at home dont u?
Don't use a torch, as others said it's bad news.. Haven't seen one blow up yet, but I'm sure we've all seen what one can do when it does...
I am your penalty.....
yeah...no torches. If you have ever messed around with aluminum and a oxy/acetalyne torch you would know why. Heat can drastically change the properties of aluminum. Even a weak little propane torch over time will weaken the aluminum. And then its just a matter of time.
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Originally posted by marKo
torch
torch
Mark
STS Power Dealer
www.pcstreetcars.com
STS Power Dealer
