My $30 Flow Bench Kit
Old 01-09-2005 | 08:34 PM
  #21 (permalink)
0HP930's Avatar
Guest
A look down the flow measurement tube.
Old 01-09-2005 | 08:36 PM
  #22 (permalink)
0HP930's Avatar
Guest
And the complete flow measurement unit.
Old 01-09-2005 | 08:39 PM
  #23 (permalink)
0HP930's Avatar
Guest
And of course a good flow bench needs a bench to put the tested item on so I went to work on making one out of plexi. Now I just need a hole saw and a few more scrap pieces of plexi.
Old 03-27-2005 | 05:57 PM
  #26 (permalink)
0HP930's Avatar
Guest
Well, I finally got around to finishing up my flow bench project.
This means I should be able to flow my heads and manifold and get them put together pretty soon.
I threw one of my ported heads on the finished rig and maxing out the pump I was flowing 5% more CFM using only half the vacuume I previously did through the same 0.4" intake valve opening.
Old 03-27-2005 | 06:00 PM
  #27 (permalink)
0HP930's Avatar
Guest
Here is a pic of the whole thing.
And a close up of the cylinder/head set up
And a close up of the home made manometer pressure gauges.
And a shot down the test flow tube
Old 04-18-2005 | 06:55 PM
  #28 (permalink)
0HP930's Avatar
Guest
Well, my intake ports are done, and flowing very well to boot. If my numbers are correct I am flowing better than a set of high peformance small block heads.
The numbers represent an improvement of better than 40% over the stock ports.
All of my heads are also within 1% of each other.
Here is a chart I made of my flow numbers for different valve lift.
Old 04-18-2005 | 07:15 PM
  #29 (permalink)
351coupe's Avatar
refinish artist
Nice set up,don't you have a flowbench at work?Can you do V8 heads?I really would like to get an idea what mine are flowing.
Old 04-18-2005 | 10:40 PM
  #30 (permalink)
Jus Skott's Avatar
.arrow Jus Skott
WOW!!! I feel way smarter reading this thread.... You get my thumbs up any day brother....
~skottie b...
Tho I havea question lets say taht one of 'em arnt flowing equal to the other's... Do you fix it yourself or do you have to take them to a shop to have them do it....
~skottie b...
TR Wondering WTH I moved from FL Member.
Back Then: A stupid Question was one that wasn't asked.
Today: A stupid question is one that wasn't Googled / Ixquicked first.
