Car Laws
Car Laws
I found this website about vehicle laws in Florida, hopefully someone can use this to fight a ticket or something.
Statutes & Constitution :View Statutes :->2005->Chapter 316 : flsenate.gov
I listed some useful ones below
Title XXIII
MOTOR VEHICLESChapter 316
STATE UNIFORM TRAFFIC CONTROLView Entire Chapter
316.293 Motor vehicle noise.--
(1) DEFINITIONS.--The following words and phrases, when used in this section, shall have the meanings respectively assigned to them in this subsection, except where the context otherwise requires:
(a) "dB A" means the composite abbreviation for the A-weighted sound level and the unit of sound level, the decibel.
(b) "Gross combination weight rating" or "GCWR" means the value specified by the manufacturer as the loaded weight of a combination vehicle.
(c) "Gross vehicle weight rating" or "GVWR" means the value specified by the manufacturer as the loaded weight of a single vehicle.
(d) "Sound level" means the A-weighted sound pressure level measured with fast response using an instrument complying with the specification for sound level meters of the American National Standards Institute, Inc., or its successor bodies, except that only A-weighting and fast dynamic response need be provided.
(e) "Department" means the Department of Highway Safety and Motor Vehicles.
(2) OPERATING NOISE LIMITS.--No person shall operate or be permitted to operate a vehicle at any time or under any condition of roadway grade, load, acceleration, or deceleration in such a manner as to generate a sound level in excess of the following limit for the category of motor vehicle and applicable speed limit at a distance of 50 feet from the center of the lane of travel under measurement procedures established under subsection (3).
(a) For motorcycles other than motor-driven cycles:
Sound level limit Speed limit
35 mph or lessSpeed limit
over 35 mphBefore January 1, 197982 dB A86 dB A On or after January 1, 197978 dB A82 dB A
(b) For any motor vehicle with a GVWR or GCWR of 10,000 pounds or more:
over 35 mph On or after January 1, 197586 dB A90 dB A
(c) For motor-driven cycles and any other motor vehicle not included in paragraph (a) or paragraph (b):
Sound level limitSpeed limit
over 35 mph Before January 1, 197976 dB A82 dB A On or after January 1, 197972 dB A79 dB A
(3) MEASUREMENT PROCEDURES.--The measurement procedures for determining compliance with this section shall be established by regulation of the Department of Environmental Protection as provided in s. 403.415(9), in cooperation with the department. Such regulations shall include the selection of measurement sites and measurement procedures and shall take into consideration accepted scientific and professional methods for the measurement of vehicular sound levels. The measurement procedures may include adjustment factors to be applied to the noise limit for measurement distances of other than 50 feet from the center of the lane of travel.
(4) APPLICABILITY.--This section applies to the total noise from a vehicle and shall not be construed as limiting or precluding the enforcement of any other provisions of this chapter relating to motor vehicle mufflers for noise control.
(5) NOISE ABATEMENT EQUIPMENT MODIFICATIONS.--
(a) No person shall modify the exhaust system of a motor vehicle or any other noise-abatement device of a motor vehicle operated or to be operated upon the highways of this state in such a manner that the noise emitted by the motor vehicle is above that emitted by the vehicle as originally manufactured.
(b) No person shall operate a motor vehicle upon the highways of the state with an exhaust system or noise-abatement device so modified.
(6) EXEMPT VEHICLES.--The following are exempt from the operation of this act:
(a) Emergency vehicles operating as specified in s. 316.072(5)(a).
(b) Any motor vehicle engaged in a professional or amateur sanctioned, competitive sports event for which admission or entry fee is charged, or practice or time trials for such event.
(c) Any motor vehicle engaged in a manufacturer's engineering, design, or equipment test. (d) Construction or agricultural equipment either on a job site or traveling on the highways. (7) VIOLATIONS.--A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
316.272 Exhaust systems, prevention of noise.--
(1) Every motor vehicle shall at all times be equipped with an exhaust system in good working order and in constant operation, including muffler, manifold pipe, and tailpiping to prevent excessive or unusual noise. In no event shall an exhaust system allow noise at a level which exceeds a maximum decibel level to be established by regulation of the Department of Environmental Protection as provided in s. 403.061(13) in cooperation with the Department of Highway Safety and Motor Vehicles. No person shall use a muffler cutout, bypass or similar device upon a vehicle on a highway.
(2) The engine and power mechanism of every motor vehicle shall be so equipped and adjusted as to prevent the escape of excessive fumes or smoke. (3) A violation of this section is a noncriminal traffic infraction, punishable as a nonmoving violation as provided in chapter 318.
316.191 Racing on highways.--
(1) As used in this section, the term:
(a) "Conviction" means a determination of guilt that is the result of a plea or trial, regardless of whether adjudication is withheld.
(b) "Drag race" means the operation of two or more motor vehicles from a point side by side at accelerating speeds in a competitive attempt to outdistance each other, or the operation of one or more motor vehicles over a common selected course, from the same point to the same point, for the purpose of comparing the relative speeds or power of acceleration of such motor vehicle or motor vehicles within a certain distance or time limit.
(c) "Racing" means the use of one or more motor vehicles in an attempt to outgain or outdistance another motor vehicle, to prevent another motor vehicle from passing, to arrive at a given destination ahead of another motor vehicle or motor vehicles, or to test the physical stamina or endurance of drivers over long-distance driving routes.
(2)(a) A person may not:
1. Drive any motor vehicle, including any motorcycle, in any race, speed competition or contest, drag race or acceleration contest, test of physical endurance, or exhibition of speed or acceleration or for the purpose of making a speed record on any highway, roadway, or parking lot;
2. In any manner participate in, coordinate, facilitate, or collect moneys at any location for any such race, competition, contest, test, or exhibition;
3. Knowingly ride as a passenger in any such race, competition, contest, test, or exhibition; or
4. Purposefully cause the movement of traffic to slow or stop for any such race, competition, contest, test, or exhibition.
Any person who violates any provision of this paragraph commits a misdemeanor of the first degree, punishable as provided in s. 775.082 or s. 775.083. Any person who violates any provision of this paragraph shall pay a fine of not less than $500 and not more than $1,000, and the department shall revoke the driver license of a person so convicted for 1 year. A hearing may be requested pursuant to s. 322.271.
(b) Any person who violates paragraph (a) within 5 years after the date of a prior violation that resulted in a conviction for a violation of this subsection commits a misdemeanor of the first degree, punishable as provided in s. 775.082 or s. 775.083, and shall pay a fine of not less than $500 and not more than $1,000. The department shall also revoke the driver license of that person for 2 years. A hearing may be requested pursuant to s. 322.271.
(c) In any case charging a violation of paragraph (a), the court shall be provided a copy of the driving record of the person charged and may obtain any records from any other source to determine if one or more prior convictions of the person for violation of paragraph (a) have occurred within 5 years prior to the charged offense.
(3) Whenever a law enforcement officer determines that a person was engaged in a drag race or race, as described in subsection (1), the officer may immediately arrest and take such person into custody. The court may enter an order of impoundment or immobilization as a condition of incarceration or probation. Within 7 business days after the date the court issues the order of impoundment or immobilization, the clerk of the court must send notice by certified mail, return receipt requested, to the registered owner of the motor vehicle, if the registered owner is a person other than the defendant, and to each person of record claiming a lien against the motor vehicle.
(a) Notwithstanding any provision of law to the contrary, the impounding agency shall release a motor vehicle under the conditions provided in s. 316.193(6)(e), (f), (g), and (h), if the owner or agent presents a valid driver license at the time of pickup of the motor vehicle.
(b) All costs and fees for the impoundment or immobilization, including the cost of notification, must be paid by the owner of the motor vehicle or, if the motor vehicle is leased or rented, by the person leasing or renting the motor vehicle, unless the impoundment or immobilization order is dismissed. All provisions of s. 713.78 shall apply.
(c) Any motor vehicle used in violation of subsection (2) may be impounded for a period of 10 business days if a law enforcement officer has arrested and taken a person into custody pursuant to this subsection and the person being arrested is the registered owner or coowner of the motor vehicle. If the arresting officer finds that the criteria of this paragraph are met, the officer may immediately impound the motor vehicle. The law enforcement officer shall notify the Department of Highway Safety and Motor Vehicles of any impoundment for violation of this subsection in accordance with procedures established by the department. The provisions of paragraphs (a) and (b) shall be applicable to such impoundment.
(4) Any motor vehicle used in violation of subsection (2) by any person within 5 years after the date of a prior conviction of that person for a violation under subsection (2) may be seized and forfeited as provided by the Florida Contraband Forfeiture Act. This subsection shall only be applicable if the owner of the motor vehicle is the person charged with violation of subsection (2). (5) This section does not apply to licensed or duly authorized racetracks, drag strips, or other designated areas set aside by proper authorities for such purposes.
316.183 Unlawful speed.--
(1) No person shall drive a vehicle on a highway at a speed greater than is reasonable and prudent under the conditions and having regard to the actual and potential hazards then existing. In every event, speed shall be controlled as may be necessary to avoid colliding with any person, vehicle, or other conveyance or object on or entering the highway in compliance with legal requirements and the duty of all persons to use due care.
(2) On all streets or highways, the maximum speed limits for all vehicles must be 30 miles per hour in business or residence districts, and 55 miles per hour at any time at all other locations. However, with respect to a residence district, a county or municipality may set a maximum speed limit of 20 or 25 miles per hour on local streets and highways after an investigation determines that such a limit is reasonable. It is not necessary to conduct a separate investigation for each residence district. The minimum speed limit on all highways that comprise a part of the National System of Interstate and Defense Highways and have not fewer than four lanes is 40 miles per hour, except that when the posted speed limit is 70 miles per hour, the minimum speed limit is 50 miles per hour.
(3) No school bus shall exceed the posted speed limits, not to exceed 55 miles per hour at any time.
(4) The driver of every vehicle shall, consistent with the requirements of subsection (1), drive at an appropriately reduced speed when:
(a) Approaching and crossing an intersection or railway grade crossing;
(b) Approaching and going around a curve;
(c) Approaching a hill crest;
(d) Traveling upon any narrow or winding roadway; and
(e) Any special hazard exists with respect to pedestrians or other traffic or by reason of weather or highway conditions.
(5) No person shall drive a motor vehicle at such a slow speed as to impede or block the normal and reasonable movement of traffic, except when reduced speed is necessary for safe operation or in compliance with law.
(6) No driver of a vehicle shall exceed the posted maximum speed limit in a work zone area. (7) A violation of this section is a noncriminal traffic infraction, punishable as a moving violation as provided in chapter 318.
Title XXIII
Last edited by Nissan Racer; 12-02-2006 at 04:53 PM. Reason: included some useful ones
Alot of people on the 19 need to crave this into your brains.
