Twin Turbo Porsche Carrera (993)
post pics of said rx7, im intrigued to see what it looks like now.....
fender flares look nice, but i wouldve went a little different with the exhaust and dumps, cars fucking sick none the less though.
SUCH IS THE RULE OF HONOUR.
Thats fucking beautiful...
-Induction Performance ALPHA Tuned.
-ROQUE MACHINE SHOP For ALL your fabrication needs.
Here are the pics of Dewains car (LS1FD)
https://www.tamparacing.com/forums/m...cs-my-car.html
That Porsche is sweet.
Patrick -
Patrick -
quite possibly the worst idea i've ever heard. thats a SHITLOAD of weight on the rear end, and NO weight on the front. hello understeer!!!!
and the gt3 is a 997 based porsche, and doesnt have as much hp as the normal 997 turbo.
and im either getting a 993 or a 964 as my next car
I <3 RooR!!!!!!
I <3 RooR!!!!!!
Princeton Wong's car - he's an engineering student based out of houston. The sick part is he fabbed up most of the intake and turbo plumbing. Boy has some skilz
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower"
-Mark Donohue
-Mark Donohue
ITBs test fitment for plenum fabrication.
First look of the full hot side of the turbo system mounted.
Bracket for the turbo.
-Mark Donohue
-Mark Donohue
Here are some of mine....
(and I forgot to change my ISO so they are dark)
Oil scavenge pump mounting bracket:
With pump on the car.
Charge pipe from intercooler to intake (drivers side) with wiggins clamps:
Intercooler cooling air distribution system:
Tubing to get air from engine cooling fan.
Clean Y to split the air.
Duct that fits over intercooler face.
All mounted on the car.
-Mark Donohue
-Mark Donohue
Racepak Dash and DAS mounted on a carbon instrument panel cover.
Carbon fiber hood and decklid supports from Seine Systems since the stock shocks lifted the carbon hood and decklid.
Freshly fabricated aluminum water tank I built for the water cooling system that circulates through the ball bearing cores of the turbos. This was made to fit under the drivers side rear bucket seat. The Meziere water pump is mounted to the tank.
Pic of the cardboard water tank mock up just for kicks.
Setrab cooler for the system.
-Mark Donohue
-Mark Donohue
yeah that has alot of very nice work and effort into it..
...and you people couldve just said the ls1fd, easier than knowing the car by the owners name.
