From the folks who can sell you gas with water and make more $ than by selling AVGAS.
Why not Avgas in your car?
By Sunoco FuelsSep 13, 2024 |Sunoco, Sponsored Content,
gasoline, Fuel Facts, Avgas | Posted in Features | From the Sept. 2020 issue | Never miss an article
This isn’t a new idea: Why not run aviation fuel in your classic? Thanks to its high octane and lack of ethanol, this avgas sounds intriguing.
High Octane:
Pump fuel intended for cars and trucks is rated on the Anti-Knock Index, which is the average between the Research Octane Number and the Motor Octane Number. Avgas, however, is rated on a slightly different scale. As a result, the avgas 100 found at many regional airports would have about as much knock resistance as a 105-octane fuel intended for cars and truckHighly Refined:
Zachary J. Santner, technical specialist at Sunoco Race Fuels, notes that avgas can be more refined and consistent than the fuel found at the corner store. Vapor pressure for avgas, he explains, often falls between just 5.5 and 7.1 psi; depending on the season and location, typical pump fuel for passenger cars can range from 5 to 15 psi. However, Santner adds that his company’s race products never deviate, always following the same formula.Zero Ethanol:
Avgas doesn’t contain any ethanol. While ethanol can help gasoline make more power, it can also cause hardware issues in older vehicles. “Can’t pull your plane over on the side of the road if there’s a problem with the fuel system,” Santner notes.Some Lead:
Not only does lead cause smog, but it’s not compatible with the oxygen sensors and other pieces of emissions equipment found in most cars built since the ’70s. Even avgas 100LL, a newer, low-lead option, still contains lead–about 1.9 grams per gallon.Legality and Logistics:
Avgas isn’t taxed for road use, and cars might not be welcome on the taxiways at the local airport.Unnecessary Additives:
Avgas contains some of the same additives found in pump fuel, including corrosion inhibitors and antioxidants that increase shelf life. However, some of its additives aren’t found in car fuels–like compounds that prevent icing and static electricity. “It’s just more additives that you don’t need,” Santner notes. “Car gas has additives designed for cars, and airplane gas has additives designed for airplanes.”More Fuel Facts from Classic Motorsports:
• What is race gas?• Which race fuel is right for you?
• Buying and storing race fuel
• The right fuel in the fall might help your engine start in the spring
• Fuels for storage: good, better, best
• How much octane is enough for my classic?
• 93-octane not enough? Solutions exist.
• Can you blend fuels to get the right mix?
• Tuning for today's oxygenated fuels
• Picking the proper gas
• How to choose a quality gas station
• Why is there ethanol in our gasoline?
• Understanding additives
• Why not avgas in your car?
• Water is great for your plants, not so much for your fuel system
• Gasoline makes a terrific degreaser, yet this practice can kill you
• Are high-octane fuels more stable?
• Ideal fuels for wintertime storage
• What ever happened to leaded gasoline?
• Homebrewed, non-ethanol fuel: A potentially deadly DIY
• Was yesterday's gasoline better?
• Cars that sit need clean fuel, too
• Is all that alcohol good or bad?
• Does the octane number in your manual match the one on the pump?
• What's the right fuel for forced-induction cars?
• What's in aftermarket additives anyway?
• The perils of running rich
• Should you fill up your classic before parking for the winter?
• Do all gas stations offer the same quality of fuel?
• How to know if you are using the correct fuel
• How to keep carbon deposits out of your engine
• Does Ethanol actually corrode metals and plastics?
• The valuable benefits of running a race fuel
• Flex fuel: Should you reach for that nozzle?
More Fuel Tips from Grassroots Motorsports:,,,but really from Sunoco...shhhh
By Sunoco Fuels
Sep 13, 2024 |Sunoco, Sponsored Content,...essentially an ad.
• What separates a race fuel from a street fuel?
• The science of high-octane fuel
• What happens to gasoline as it ages?
• Ethanol or not for your gasoline?
• Does all E85 contain 85% ethanol?
• Why does E85 run cooler and make more power?
• More oxygen for more power?
• Why not methanol?
• What's lead got to do with it?
• Picking the proper gas regarding lead and oxygen
• Narrowing the fuel field
• 91 vs. 93 octane
• Why top tier street fuels matter
• Fueling your boosted engine
• What fuel to feed a rotary engine?
• Lawn and garden equipment needs the proper fuel, too
• What is vapor pressure of gasoline and why should you care?
• What is specific gravity of gasoline and why should you care?
• Adding additives to your fuel. | Yes or no?
• What's really in that fuel additive?
• Antioxidants, fuel stabilizers, and you
• Winter fuels for wintertime
• Fuels for a post-apocalyptic world
• Need help selecting a fuel? Call the experts.
• Gas station basics that aren’t that basic
• How dirty fuel can lead to a dirty engine
• Is all premium gas the same?
• How to buy and store race fuel
• Toluene or Xylene: Legit low-buck octane boosters?
• How to make your own ethanol blend
• Do fuel additives actually work?
• Where does gasoline comes from?
• How to stretch the gas budget?
• How fresh is that fuel?
• How to handle gasoline safely and remain fire-free
• Expert tips on finding and transporting race fuel
• How to make the jump into the world of race fuels
• How to clean intake deposits in direct-injection engines
• What's up with midgrade gas?
• Is 110-Octane Standard a race fuel easy button?
• Are tired, old fuel injectors robbing performance?
• Does your engine need an upper cylinder lubricant?
7
10-17-2022 11:32 AM
09-29-2022 01:41 AM
01-01-2020 04:48 PM
American Iron Tech
4
09-06-2019 02:41 AM
