TT346 LS1 goes 8.5 @ 162 with stock crank,stock block, stock head castings
Old 09-26-2004 | 12:17 PM
HybridSS's Avatar
I have fuzzy eyebrows
Default TT346 LS1 goes 8.5 @ 162 with stock crank,stock block, stock head castings
Harlan again Hes kicking ass on that combo. He still hasnt turned the boost all the way up yet.
Here is a link to some vids and info.
http://ls1tech.com/forums/showthread.php?t=220418
if it's cheap & reliable, it ain't fast, if it's fast & cheap, it ain't reliable, if it's fast & reliable, it ain't cheap
Old 09-26-2004 | 02:30 PM
gator's Avatar
Underdog
simply amazing. oh and al, technically he is on a stock pcm as well. just uses his electronics to control the fuel injectors.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old 09-26-2004 | 03:09 PM
HybridSS's Avatar
Thats true Gator...I need to ask him about hooking me up with a MAF summing box so I can run dual MAFs. Hes a tightlipped bastard sometimes though..
Old 09-26-2004 | 03:30 PM
Suicidal Racing's Avatar
Has V.I.P in HELL!
so he is the fastest ls1 now right.unless ronnie duke has gone faster then the 8.54 that he ran
Old 09-26-2004 | 03:37 PM
HybridSS's Avatar
Actually..Harlan went 8.5x something. Not sure if he is actually the fastest. I am sure he will be the fastets soon.
There are prbably a few high 7 second LS1s being built right now though.
Old 09-26-2004 | 06:59 PM
gator's Avatar
Underdog
harlan is slower by something like .06 of a second. 8.521 to a 8.527 (harlans). ronnie also ran 165.x when i saw him at the TR Shootout.
pushing the turbos a bit harder, harlan will overtake him. esp considering harlan's car was "only " in the 1.35 60' range.
Old 09-26-2004 | 08:17 PM
Has V.I.P in HELL!
from what i understand is ronnie has a ton left in that car i think he was only running like 20 pounds of boost or less and that blower he has can make 30+ pounds of boost.i know they are both sick cars.and i would love to watch them run.
Old 09-27-2004 | 05:28 PM
Gunslinger09's Avatar
Devils advocate
Originally posted by Scott
Yep, want to go fast get a turbo.
No need for high dollar trick heads and all of the pther things that go with them.
Well it helps that Ls1 stock heads flow around 235 CFM.
98 Z28 A4/LS1
Sport Gold Metalic
God I Hate Ricers
Old 09-27-2004 | 06:16 PM
HybridSS's Avatar
No no...they were stock LS1 castings. They are still reworked with larger valves and porting. Probably flow in the 300 cfm range at .600 lift. About a $1400-1500 head if I had to guess.
