2003 cadillac Deville window won't move
i noticed that my right rear window would not roll down if i used the button on the drivers door.
if i used the button on the right rear door, it would work.
over the weekend, the window slid down, broken regulator...
replaced the regulator, plugged everything back together, now all i get is a click when any button is pushed to get the right rear down.
all other windows work perfectly
the clicking was coming from the rear door module. i removed that and opened it and (i'm not a computer board electrictian) nothing looked out of the ordinary.
any ideas as to what could be causing this?
cliff notes
drivers door would not operate right rear door
right rear door switch would operate right rear door
replaced regulator
right rear window is inoperable regardless of switch used
loud clicking noise coming from door module when window button pressed
cliff notes
replaced regulator
