Turbo Car Burning Oil
Old 08-06-2003 | 10:05 AM
  #21 (permalink)
Trip's Avatar
Dramatic Lemur
Thicker oil fixed you.
"Never attribute to malice that which can be adequately explained by stupidity."
AIM: TurboedTrip
Old 08-06-2003 | 04:46 PM
  #22 (permalink)
Spence's Avatar
"TEAM WHITEY"
Can someone explain why thicker oil would fix his problem? Why was the thinner oil getting past the rings?
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old 08-08-2003 | 07:43 AM
  #23 (permalink)
AmsoilDealer's Avatar
The thicker oil did not "fix" a problem. No oil can "fix" a mechanical problem.
The thicker oil IS less prone to slip past rings and valve guides and therfore burn less and this probably what has helped QuickCivic.
This does not suggest that thicker is always better. Modern cars are designed to run on 30wt. oil and as such, you should run your car on the thinnest oil as recommended in the owner's manual.
Don
Old 08-09-2003 | 11:13 PM
  #25 (permalink)
Sunrise City Rider's Avatar
WHAT!?! OK!......
Don
Running on the thinnest oil possible will add a few HP and give you better gas mileage, but it will also reduce oil pressure a bit and should not be used for a street car with a "race" engine...
Also, JE pistons are known to burn oil when the engine is not running hard, due to the "relaxing" of the aluminum and when its running hard, the aluminum expands and seals more complete...
This may occur on other pistons but JE is notorious for this...
Zee
I work too damn Hard...
04 Civic Si
01 Lexus GS300
Old 08-10-2003 | 07:21 AM
  #26 (permalink)
Tony's Avatar
Senior Citizen
Well at least you have it isolated to when the engine is under vaccum, which could be valve seals or I guess the turbo seals, the fact that it is nopt burbing it at WOT is a good thing. I doubt it's a broken ring. But that is easy enough to test for.
10' 1198S
09' Ninja 500R
09' Stella
Old 08-10-2003 | 04:12 PM
  #27 (permalink)
fresh&clean's Avatar
I love Lamp
My car is leaking oil the same way but has no turbo but it only leaks when I start it up and let it idle its like the size of a quarter i need to get it fixed but im not sure what it is yet I hate the smell of burning oil.
