Turbo Car Burning Oil
Old 08-04-2003 | 06:47 AM
quickcivic's Avatar
addicted to boost
Question Turbo Car Burning Oil
Alright here is what is going on...
Have a fairly new - (8000mile) built engine, turbo charged with a Garrett T3/T04E Turbocharger.
Since the engine and turbo were new I have been using 10w30 dino oil. The car would occasionally burn oil out of the blue when idling, maybe once a couple of days.
As you may know, turbo VTEC cars use oil. So when my car has been low on oil the past couple of weeks I have been adding Mobil 1 10w-30 to get it prepared for the switch to Synthetic and kind of wean the engine off of dino oil gradually. I have put about a quart and a half total by now.
Well now the damn thing will burn oil when cold in the morning. Once it gets to temp, it stops. When I get on it - it does not burn oil. When I am at a stop light it will burn oil every once in a while, not all the time - and it is quite a bit of smoke. Car runs fine and nothing seems to be wrong and it only burns oil at idle. Could my turbo seals be going bad? Any suggestions?
I am going to drain the oil and put in full Mobil 1 10w-30 and see what happens.
Thanks for your help....
Old 08-04-2003 | 06:51 AM
Spence's Avatar
"TEAM WHITEY"
Damn Alex that sucks man if you need some help holla man send a pm
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Tits McGee's Avatar
is cooler than you
I didn't think you were supposed to mix reg. oil with synthetic. Maybe that's your problem.
Old 08-04-2003 | 08:14 AM
EG6's Avatar
EG6
When the motor was rebuilt. Was the block bored .020 over or just a light hone? Burning oil on cold starts is a bit normal and stops when it reaches temp may be a cause of thermal expansion.Run a compression & leak down test to determine if there is any serious problem other than that just change the oil. Royal Purple is great but a bit expensive.
Old 08-04-2003 | 09:32 AM
quickcivic's Avatar
addicted to boost
The engine is fine. It was built by import builders in CA and it has Golden Eagle Sleeves. I really doubt anything is wrong with the block. I am thinking it is the turbo. I am going to go full synthetic and see what happens. I am going to replace the turbo and exhaust manafold anyway next month.
Cronic, thanks for the info. I check my oil levels every morning before I start it up. How hard is it to replace the valve stem seals? How much do the parts cost?
Spence, I will let you know if I need any help. Thanks for offering...
Old 08-04-2003 | 09:36 AM
Alpha's Avatar
What about the intake pipes before the intercooler? Any signs of oil?
- Induction Performance
* IP E-Mail
* IP Face Book
* IP Web-Site
Old 08-04-2003 | 10:36 AM
quickcivic's Avatar
addicted to boost
Good idea.
I'll check that and see what I find.
