single cam internals question
Equal Opportunity Hater
on
im new to the whole single cam scene. im building my first single cam for nitrous. i have eagle h beam rods and srp pistons out of a single cam vtec motor. Now my question is can i use these pisonts and rods in a single non vtec (d16a6 block)? also i have a zc block. the block is stamped zc, now would i be able to use the forged pistons and rods from the single vtec motor on this zc block? let me know please
JDM Hater #001 PITBULL, "the most diabolical JDM/all around HATER"
It's not that the JDM itself is bad. When everything is JDM, When you think you're JDM, When your US car is JDM cause of your taillights. When YOU are JDM. YOU are GAY!
Guest
Posts: n/a
Im pretty sure the SOHC VTEC pistons would drop the compression in both motors a point or so, but I believe you can use them in both motors and be happy. You would make more power putting those pistons in a SOHC VTEC block/head though. Your kinda doing the reverse of what most people do.
check out www.d-series.org If you cant find your answers here. They have some good info on the SOHC.
Tim
Tim
zc rods and d16a6 piston yield good HP, and compresion
Top Dead Center Performance
Mobile Alabama 251 661 6067
owner/operator
www.tdcperformance.net
owner/operator
Here is a new site dedicated to the D Series.
http://pub161.ezboard.com/bbseriesalternative
Some of our members you may have heard of, Mista Bone, Bisimoto, and Zex Man. We're about to get a domain name of alternativehonda.com.
-00 Civic EX Coupe BUILT D16Y8, Precision SC50, 12.80@105.8 14psi
-00 Chevrolet S10 LS 4.3L V6 Gas Guzzler
http://www.Sohchonda.com
Honda SOHC & D Series Resource
