Motor turns on then turns off
Old 01-17-2004 | 08:10 PM
MacGruber's Avatar
MaDe Of MoNeY
Default Motor turns on then turns off
The motor turns on then boggs down and shuts off. Then not a second later i turn the motor back over and it starts up and it runs fine. Any ideas why it wont start up on the first time anymore it used to never do it. Thanks im trying to learn. Also I did a search and nothing turned up. PS its a 1989 honda hb dx thanks again
Old 01-17-2004 | 08:39 PM
MacGruber's Avatar
MaDe Of MoNeY
There is no error codes. Would the fuel pump have a sensor on it to show if it was going bad? Where would I find the relay at? I need a to a Haynes manual for the car. will pick it up in the morning.
Old 01-17-2004 | 09:16 PM
LGCubana's Avatar
Goal; 400 Whp GST
I would start with simple things. Like your plugs & distributor cap. R U putting out white or black smoke with the first cold start ?
Smoke'm
Old 01-17-2004 | 09:33 PM
lowoctane's Avatar
Professional Dumbass
or when you start up the car, just turn the key to turn on all the accesories but not enough to start it, say wait about 8 seconds then turn it the rest of the way to start it up.
if ya get what im saying....
???cause dont the fuel pumps turn on right before the startup????
Itz jus' fo deckarayshunz man jus' fo deckarayshunz
Old 01-18-2004 | 05:21 AM
rangcrx's Avatar
engine building &best
like crix he fixed mine when it did that,try turning the key on light check engine light go out turn off then turn the car on again then start it see if it gets enofe fuel then to start
i love AUTOZONE
Old 01-18-2004 | 06:53 AM
MacGruber's Avatar
MaDe Of MoNeY
im putting out a little white smoke. but thats only because its cold out side. Ill check my plugs and wires and ill look at my distributor. Ill also try the Idea on waiting 8 seconds then start it up also. I will try all of the ideas guys thanks alot ill let you know how it went. Thanks alot one more time.
Old 01-18-2004 | 08:32 AM
Spyderxl98z24's Avatar
Honda Tech/ Local AssHole
Originally posted by crix
It maybe the Main relay for the fuel pump/ECU going bad.or it could be
the fuel pump........test the fuel pump/Relay for volts & check the ecu for codes.......
once again overdoing it! Main relay would just not work if the pump cycled its working fine. once you have fuel pressure the pump basicly shuts off and the ventury vacum affect keeps the fuel flowing until more Throttle is applied and ups the voltage on the Pump circut increasing the psi on te pump and so forth. Pump cycle = circuit fine !
Tune up ! Check your fuel pressure ! Problem solved. ECM doesnt control Fuel pump priming, The first 8seconds of the FIRST ignition cycle the fuel system primes itself. The ECM hasnt even cycled by then. Check for fuel pressure and posibly run some cleaner in the tank if that doesnt clear it up then replace the pump being that old it coud be a good idea. But do a tune up, that always is a good idea. Cap Rotor Plugs Wires. But im guessing dirty fuel system or dieing pump.
oh FYI engine codes are not stored in pre OBD systems hmm nice try genious !! check the year again !
Old 01-18-2004 | 11:55 AM
MacGruber's Avatar
MaDe Of MoNeY
I tryed the 8 second thing and it work! so I just put some injector cleaner in it and ill add some fuel line cleaner also ill change the fuel filter
Old 01-18-2004 | 02:03 PM
see issue solved !! try the simple shit first !!
Old 01-18-2004 | 06:09 PM
MacGruber's Avatar
MaDe Of MoNeY
Thanks alot. Are you a mod? If your not I would recomend you. You give some helpful info. Keep up the good work. Thanks again
