Dumb Question Need A Quick Answer
screwdriver: between fliter and block. just don't scratch or dent anything!
by http://www.flickr.com/people/8341770@N07/, on Flickr
– the late Tom Thrash SCCA Solo E Production
Originally posted by smoke3
ok the screw driver thing HUH. where do i stick the screw driver into.
stab the filter with the screw driver and start turning.
TR happily married crew-member #2
___________________
___________________
This is the internet. You're just supposed to talk up whatever you do know as if you're a salesman for it. i.e. I drive a Supra and a Corolla therefore 2JZ is the greatest and so is the 4A and I don't care about anything else because it's all crap since I don't have it. I also have a stack of $20 bills in front of me, therefore 20>50 and 20>100 and 20>1000. $20 bill FTW.
Guest
Posts: n/a
Originally posted by Pharaoh
this is the fun way, but its messy, the fram one i got has a black coating for grip on it, and its easy to bare hand it
-Keith
Guest
Posts: n/a
ok what is the throw out bearing ??? i read couple post about it and my clutch feels fine. Other than the fact that i need a new clutch. The clutch pedal is stll hard and not mushy or anything. Only thing i have noticed was switching gears was a tooo a little bit more effort??
-Keith
ok i just went outside to check the noise when pushing in the clutch. It is still there when u push the clutch in. i put my ear on the distrubutor and i can still here the same noise, but its not as loud as a cold start
damnn that might be a little confusing
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
The Myspace Page
made.
- Its Game Time -
get a filter wrench 15$ at sears. best thing to use or whackoff more build up your hand strength. it shouldnt be on that tight that you cant unscrew it by hand. too tight can crush the filter inside and not work properly you are overtightening it. 1/4 turn after it seals is all you need.
