Clutch Master/Slave Cylinder
Old 05-23-2004 | 06:19 PM
smoke3's Avatar
Its a secret
Default Clutch Master/Slave Cylinder
Ok need someones opinion here. about a month ago my clutch fluid was completely drained and i was like what the fuck so i bleed the system and refilled it and tightened the bolts on my clutch slave cylinder.
I went to the shop the next day and they guy was like ur master cylinder is going bnad too cause there is fluid on ur carpet. I said ok.
Now today i check it and its still full. wtf. my carpet has no new stains (actually the so called stains on my carpet were from the grease used in the master cylinder.
My Clutch fluid level is still normal and it shifts fine. Should i still replace them or just leave it alone until it actually fucks up
thansk guys
The Myspace Page
Hero's arent born there american
made.
Aco. 53rd CSB LTF - TMT - 1st SQD
Afganistan Tour 2005 - 2006
- Its Game Time -
Old 05-23-2004 | 07:28 PM
Echo7847's Avatar
If its leaking grease then yes replace it, theyre not expensive and you can install them yourself.
